How can i block diffs???
hi boys.i want to know how can i block-spool a center diff.
i had read in a mag sometime ago for a piece that you can put in the diff case as reasult to block it.[but i cant find this mag now]
some other way is to replacy the case with an axle but keep the same diff gear.
do you know guys a company with these products?
Thanks in advice!
Thanks in advice!
When I run dirt oval, I put 100,000 diff oil in the center of my Superlate(1/8 scale buggy converted to latemodel). It worked pretty good for what I was doing at the time. I have heard of the JB Weld thing but I always wondered what happens when you need to change your center diff bearings?
Really??? Bearings don't spin?? I guess I they just float in air? I guess there is no need for the center diff support either.................WOW!! I would like to see a pic of that!!!
