Old 03-19-2009, 09:03 AM   #1
TXRC8racer's Avatar
Trader Rating: 19 (100%+)
Default RB S7---Turbo Head vs. Standard Head
I have a RB S7 with about 2 gallons of 30% Byron's on it now and runs like a champ!! So the question has been going thru my mind that should I put in a Turbo Head in this motor but im not sure if its worth it can get a brand new one on ebay for around 30$ thats 15$ cheaper than new.
What are the advantages of running a Turbo head motor Vs. Standard head?
Lance Plant
Sponsors: Team Associated~Reedy~LRP~Pro Line~Avid RC~Airtronics~Werks Racing
TXRC8racer is offline   Reply With Quote
Old 03-19-2009, 09:08 AM   #2
wiggit's Avatar
Alittle bit more power and fuel economy.You also will get to buy more expensive plugs and it will be more sensitive to tuning and weather changes.
wiggit is offline   Reply With Quote
Old 03-19-2009, 10:17 AM   #3
TXRC8racer's Avatar
I thought I have read that the Turbo plugs are easier to tune and hold tunes better than a standard plug, but im not sure..
Lance Plant
Old 03-19-2009, 11:05 AM   #4
Allumina's Avatar
Trader Rating: 27 (100%+)
Send a message via AIM to Allumina
nah standard plugs are easier to tune...
Another cost you may not have considered yet; Do you have a bunch of standard plugs still? If you switch to turbo you're going to have to buy plugs too and those little guys get pricey.
Turbo heads do make some more power, and burn fuel my efficiently but if you're very used to your standard button AND have a bunch of standard plugs still, I wouldnt make the switch personally.
[COLOR="Red"]Kyosho[/COLOR] - MP9 & ST-RR
A[COLOR="red"]K[/COLOR]A - Tires and Wheels[COLOR="DarkOrchid"]Novarossi Racing Engines[/COLOR] - 21-4 Plus & Toro Nero
Houstons Engine Service - [email]houstonsengineservice@live.com[/email]
Allumina is offline   Reply With Quote
Old 03-19-2009, 01:47 PM   #5
TXRC8racer's Avatar
I just bought 4 new standard RB plugs from Amainhobbies a couple of weeks ago @ 7$ a piece.
I could always use a little more time on a tank of fuel im getting around 7 min right now and im sure i could lean it a little and get 8 but i like my temps in the 225 range.
Lance Plant
Old 03-19-2009, 08:48 PM   #6
I'd stick with the standard plugs for this motor for now. Maybe you can pick up the turbo button, but continue to use the your stock button until you use up the plugs you have. One more thing to consider is that with turbo plugs, you have a fitment issue with some plugs and need to stick with a certain brand of plug. Also, once the button starts to wear, you may experience more difficulties with sealing the plug when installing a new plug versus the use of a standard plug which uses a copper spacer to seal up the plug with the button. It wont make that much of a difference to a normal racer. I'd save the money for other things and just keep turbo plugs in mind for your next motor.
HB D8T with BCE Chassis, ACE Shock towers and motor mounts, M2C Rear Suspension system, KH front steering plate and chassis braces, Lunsford Ti-turnbuckles & hinge pins, OS Speed motor, Hitec 5995TG steering, Futaba 9351 throttle/brake, OS 2060 pipe, and J concepts Punisher Body.
HB D8: CEO Mods Novarossi P5K with JP4 tuned pipe, JR 9000T steering, JR 8800T throttle.
gotspeed_2000 is offline   Reply With Quote
Old 03-23-2009, 10:35 AM   #7
TXRC8racer's Avatar
So why does it seem like the top dollar motor's come with turbo heads if the standard head plugs are a better plug? Is there much diffrence in power and fuel mileage..
Lance Plant
Old 03-23-2009, 12:47 PM   #8
mikenix's Avatar
Trader Rating: 21 (100%+)
I have a S7 with a standard plug and I recall this is all one piece button and cooling head/fins, so I think you would need more than just the button to covert to turbo.
www.answer-rcusa.com
Contact me for details.....
When you sling mud, you only loose ground. - Fat Albert
mikenix is offline   Reply With Quote
Old 03-23-2009, 01:07 PM   #9
The turbo plug usually gives a little more power due to the design of the plug and how it fits the button. Other features such as coil size and and material also contribute to the turbo plug's longevity and slight power increase.
The standard plug however uses a copper coil which helps seal the plug a little better, and this adds to the longevity of the plug and button. Also, the copper shim also helps shield the button from dirt when taking out the plug. The draw back to the copper shim is that it can also compress and change the final height of the coil within the plug.
Old 03-24-2009, 04:47 AM   #10
TXRC8racer's Avatar
On amainhobbies.com the head buttons are sold separate from the cooling head for the S7.
Lance Plant
Old 03-24-2009, 05:46 AM   #11
mikenix's Avatar
Here is the one I have and the pic even shows all one piece.
http://www.amainhobbies.com/product_...oducts_id/8951
The turbo button you need this to complete it.
http://www.amainhobbies.com/product_...ducts_id/24829
Old 03-24-2009, 06:35 AM   #12
TXRC8racer's Avatar
Im not 100% sure i have never had the head off the motor but they also sell this
http://www.amainhobbies.com/product_...oducts_id/4830
And it says for the:
RB Concept .21 Standard Plug Square Stroke (E/S5/S7/WS7III) Button Head (1) [RBC01090]
This is a replacement Standard Button head for RB Concept Square Strong .21 engines, such as the Econo 3-port, S5, S7II and WS7II family engines. This is the same as the head button that comes in the box with these engines.
Then the Turbo plug says:
http://www.amainhobbies.com/product_...oducts_id/4828
RB Concept .21 Turbo Plug Square Stroke (E/S5/S7/WS7III) Button Head (1)
[RBC01080]
This is a Turbo Button head for RB Concept Square Strong .21 engines, such as the Econo 3-port, S5, S7II and WS7II family engines. These engines usually come with a standard plug button head, so you can use this button head to convert your engine to use Turbo glow plugs for better performance!
So I will need to buy the WS7 Cooling head to run the Turbo Plug?
Lance Plant
Old 03-24-2009, 06:51 AM   #13
mikenix's Avatar
Sounds like perhaps it's changed over time. I think if you have the very round one like mine it's all one piece. Maybe the newer style is two piece. Either way you're four screws away from knowing in your case.
Old 03-24-2009, 07:15 AM   #14
TXRC8racer's Avatar
Yea i will take a look this afternoon when i get home. And i just bought this motor new from my LHS about 2 months ago.
So the only real advantage for the turbo plug is performance. But really how much more performance do these motors need? They over power the track as it is now with my stock S7, if you have the most powerfull motor out there and makes like 4hp it don't mean a thing if you cain't get it hooked up and put to the ground.
Now i can see doing the head swap if it gives me a couple more minutes of run time that means less pit stops in a main which equals more laps.
But is it really worth it for just the extra run time?
Lance Plant
Old 03-24-2009, 07:32 AM   #15
RBMike's Avatar
You will need both the head button & the heat sink to convert it (& the turbo plugs). It's not worth it. If you need better fuel economy put a smaller restrictor in the carb. I normally ran a 7.0 or 7.5 in the standard S7 but you can go even lower.
-EMBX6,T8 1400, RX8, 5S Lipo ,Elite-RC, RCM tray
-EMBX6,T8 1350, RX8, 5S Lipo ,Elite-RC, RCM tray
-B44 (Novak)
-ROAR 4 cell rule Blows
RBMike is offline   Reply With Quote
