Old 03-19-2009, 05:16 AM   #1
vti-chris's Avatar
Default Nova 367 Plus 2...owners!
What's the difference between the older and 2008 version?
Which pipe-venturi combination gives the most runtime?
What other plugs can be used (STD) apart from Novarossi-RB plugs?
Is the turbo head a huge improvement compared to the normal plug?
Xray/OS/Savox/Sanwa
Axial XR10
Sakura Zero S/Castlecreations
RCO
vti-chris is offline   Reply With Quote
Old 03-19-2009, 11:26 AM   #2
vti-chris's Avatar
Xray/OS/Savox/Sanwa
Axial XR10
RCO
Old 03-19-2009, 04:25 PM   #3
COBRARACING's Avatar
A customer of mine has completed alot of testing with turbo and standard plugs .
He tested the plugs with cars and boats using the same fuel and same nitro content in each .hot/med and cold plugs of each turbo and standard
His conclusion was that he found the standard plug to be more reliable and create more power over the turbo plug in the boats and cars .
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 03-19-2009, 06:50 PM   #4
houston's Avatar
Trader Rating: 91 (100%+)
367 likes .80mm worth of shimming and 28011 combustion chamber odo97t or 77t
one of the best exhaust systems i have seen being used with 367 is a sirio2013 pipeset and a rscomp or jp efra 2032 pipeset w/ medium round or long header .
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 03-19-2009, 07:17 PM   #5
Poppin Fresh's Avatar
I'm not so fluent in the measurement language, how many and which shims are they?
"Nothin says luvin like fresh baked muffins, woohoo!"
Cruizin With R/C, RCBZ, Xray, Hudy, Novarossi USA, Futaba, Avid RC
Poppin Fresh is offline   Reply With Quote
Old 03-19-2009, 08:46 PM   #6
houston's Avatar
two.30mm alu. shims and one .20mm or two .10mm copper , there are three different copper sizes
stock is .70mm except the 09 plus4's come with .80mm installed
Old 03-20-2009, 11:33 AM   #7
vti-chris's Avatar
And what are the differences on the previous and 2008 model?
I don;t plan on changing to turbo head yet so which normal plugs from Novarossi, O'donnell work best?
Xray/OS/Savox/Sanwa
Axial XR10
RCO
Old 03-20-2009, 04:05 PM   #8
houston's Avatar
sure , turbo works best !!! if using standard plug use odo 77 .
i will be trying novarossi plugs again this season to see if they are back up to snuff , i hope so as i would much rather recommend them .
