Old 03-18-2009, 08:29 PM   #1
Default NEED ADVICE ABOUT CARBON FIBER CHASSIS!!!
im building a road track t maxx and wanted to go lite. i found a carbon fiber chassis. what you think???
school boy is offline   Reply With Quote
Old 03-18-2009, 08:32 PM   #2
fatdaddy's Avatar
sounds awesome. for a road car, that would be great
fatdaddy is offline   Reply With Quote
Old 03-18-2009, 08:39 PM   #3
it looks killer and is nib. but worried it will crack easly from motor vibrition and stress
Old 03-18-2009, 08:53 PM   #4
fatdaddy's Avatar
i cant say anything about the parts you plan on using. but other companies have made carbon fiber chassis for full off road use, so i think using one on road should be just fine.
Old 03-18-2009, 09:00 PM   #5
how much would you think a chassis like that would cost?
Old 03-18-2009, 09:03 PM   #6
fatdaddy's Avatar
personally i dont know. google shopping to the rescue! http://www.google.com/products?hl=en...num=1&ct=title
Old 03-19-2009, 04:47 AM   #7
MrUnlimited's Avatar
I like alloy chassis since it dispatch heat better. Have you seen any pro rider using a carbon chassis (doesn't matter f it is off or onroad). In my opinion stick to the alloy chassis because if the motor becomes too hot and chassis is not made well the layers of the carbon become loose and your chassis is worthless than.
U5 Formulaboat 1/8 hydroplane - MHZ138 AQUAMANIA - Axial Exo Terra - Tamiya Avante - LC Racing EMB1 - Atomic AMZ 4WD Touring car
MrUnlimited is offline   Reply With Quote
Old 03-19-2009, 06:15 AM   #8
Integra's Avatar
i know a couple Pro's who run Carbon chassy's.
and FWIW Quality CF will NOT de-laminate from heat....when the sheet is cured in the mandrel they crank up the temp to 4-500degrees....unless your running your motor significantly hotter then that you would never dream of having the come apart.
