Old 03-17-2009, 09:31 PM   #1
ntc3bionicracer's Avatar
Send a message via ICQ to ntc3bionicracer Send a message via AIM to ntc3bionicracer Send a message via MSN to ntc3bionicracer Send a message via Yahoo to ntc3bionicracer Send a message via Skype™ to ntc3bionicracer
Default need advice
i have a used revo 2.5 it runs at idel or a little above idel but spits a mist of fuel out of the carb when engine is runnining and only runs for 2-4 minutes i can pull the muffler pipe off and it has a build up of fuel in it enought to drain some out. i even tried to cut the fuel flow adjustment way down like just enough to run engine and got the low air speed set at best to run a little pass idel. is it the carb or engine the problem.??
ntc3bionicracer is offline   Reply With Quote
Old 03-17-2009, 09:40 PM   #2
snowboard094's Avatar
This shouldn't be a problem with your engine or carb it is just out of tune. Lean the low speed needle.
-Electrical wiz-Let me check your shorts.....that came out wrong
"Team Terrible"
Ofna Hyper 10sc
T-maxx O.S .18tm
snowboard094 is offline   Reply With Quote
Old 03-17-2009, 10:00 PM   #3
VenturaDC's Avatar
Trader Rating: 32 (100%+)
search up the factory needle settings, reset and tune from there.
Dustin Colt45 Aguirre
Kyosho RB6--Futaba--HW--Shuurspeed 17.5
Kyosho SCR--Hitec--Lrp--Yeah 13.5
Durango Dex210--Futaba--Trakpower--Tacon 8.5
VenturaDC is offline   Reply With Quote
Old 03-17-2009, 10:36 PM   #4
Default need advise
i've done that,, it just seems its getting too much fuel,,, low screw even with scew houseing and high speed 4-turns out,,thanks for your help
Old 03-18-2009, 03:43 AM   #5
I know this sounds weard but check the pipe real well. Could be clogged or bent at the wrong spot or leaking. Had a frends one that was cracked at the nipple for the tank line. JB Weld and rocks now.
The Working Man is offline   Reply With Quote
Old 03-18-2009, 04:24 AM   #6
rcracenut's Avatar
Trader Rating: 52 (96%+)
4 turns sounds like too much. Turn it 3 turns from slightly seated. I would start at 2- 2.5 turns out for the idle mixture. How much compression does it have? Can you feel a definate resistance when it come to the top of the stroke?
____________________________________________
1 Corinthians 10:31 ...whatever you do, do it all to the glory of God.
S&N Trackside Hobbies
Innovative Hobbies and Raceway
Clark RC race park
rcracenut is offline   Reply With Quote
Grande Prairie Model Racers Association WheelNut Canadian R/C Scene 19805 06-10-2017 01:40 PM
Mugen MTX-3 university_dave Nitro On-Road 17237 12-30-2012 12:16 PM
Serpent 720 rcrossco_1 Nitro On-Road 5073 04-16-2012 08:42 PM
Need help from all single guys... trdsupra88 Electric On-Road 92 01-31-2008 08:15 AM
ACADEMY HOBBY MODEL KITS PerformanceRC Australian Racing 33 09-12-2006 07:17 PM
Need Some Advice, Savage X or Revo Twiztid Rock Monster Trucks 32 06-05-2006 04:11 AM
