Old 03-17-2009, 05:28 PM   #1
didrace's Avatar
Default BCE st-r chassis
Hi guys i own a bce chassis but is not the version that they did for the st-rr.. it is the first one that came out for the st-r ..
i currently own the st-rr and i would like to know if anyone from you here had or knows about these chassis..
if yes do you recomend me changing the current st-rr chassis to the first generation bce chassis or shall i stay with the kyosho one..
btw the first generation bce chassis is very few mm shorter than the st-rr chassis...
didrace is offline   Reply With Quote
Old 03-17-2009, 07:14 PM   #2
NITROALM's Avatar
Exclamation
Hi the Best model is the K7-RR Pro Chassis
It is the same that was used by Ryan Maifield
Ryan Cavalieri both used to winThe ROAR Truck Nats with
you can get more info at staff@bcespeed.com
NITROALM is offline   Reply With Quote
Old 03-18-2009, 12:17 AM   #3
HaulinBass's Avatar
with the st-r bce chassis and hubs all the way back you get the same wheelbase as the strr with hubs either forward or center possition
HaulinBass is offline   Reply With Quote
Old 03-18-2009, 06:55 AM   #4
didrace's Avatar
thanks for the help guys ..
but still i did not understand which one is better to use..
is there someone who had used the chassis i have?
NITROALM i wished i had the st-rr chassis but i have the other one...
Old 03-18-2009, 08:35 AM   #5
Bigedmond's Avatar
Trader Rating: 18 (100%+)
The ST-RR chassis is based off of the Original BCE chassis. If you can, get the new BCE chassis. If you cant stick with the stock ST-RR chassis.
Bigedmond is offline   Reply With Quote
Old 03-19-2009, 02:02 AM   #6
I would stick with the stock chassis for most tracks. If you are moving to a more technical track, you could try the shorter chassis to gain a little more steering without having to run "light" fluids. The two main differences between the BCE and the stock chassis is the material they use to make it and the flex points of each chassis. The BCE chassis is top notch material.
HB D8T with BCE Chassis, ACE Shock towers and motor mounts, M2C Rear Suspension system, KH front steering plate and chassis braces, Lunsford Ti-turnbuckles & hinge pins, OS Speed motor, Hitec 5995TG steering, Futaba 9351 throttle/brake, OS 2060 pipe, and J concepts Punisher Body.
HB D8: CEO Mods Novarossi P5K with JP4 tuned pipe, JR 9000T steering, JR 8800T throttle.
gotspeed_2000 is offline   Reply With Quote
Kyosho ST-RR Tim Johnson Nitro Off-Road 4389 06-24-2017 10:47 AM
CEN Matrix TR t4usee Nitro Off-Road 1798 03-29-2010 09:57 AM
2009 Oregon Pro Series rookie042 Northwest Racers 548 12-15-2009 05:14 PM
Kyosho ST-RR $430 shipped mbunker R/C Items: For Sale/Trade 11 05-05-2009 07:08 AM
MBX5T VS. ST-RR jlo8864 Nitro Off-Road 14 12-04-2008 12:46 PM
