Old 03-17-2009, 02:35 PM   #1
halfman's Avatar
Cool What does it do when you pinch an engine???? Help
A guy told me to get my engine pinched and i dont know what that is? Please HElP!!!
halfman is offline   Reply With Quote
Old 03-17-2009, 02:41 PM   #2
Mr. Twister's Avatar
a clamp or press system is used to reduce the diamiter of the top portion of the sleeve, when doing this it creates a tighter seal at TDC, close or beyond what the engine had when it was new, u can have this done and most of the time it will help restore the compresion of the engine, but also cause more stress on the rod and crank pin due to the new tightness, it's a cheap way to get a few more weekend out of the engine.
Brian Carey
615-838-5373
Tennessee Oval Performance
Check us out on Facebook
Mr. Twister is offline   Reply With Quote
Old 03-17-2009, 02:42 PM   #3
Trader Rating: 19 (100%+)
Contact Powerhouse, he has a thread on here. He can hook you up with from what everyone says the best sleeve pinching service. It is a way to get much longer life from your engine by pinching the sleeve closed on the piston which raises compression, hence longer life. You actually have to do a small break in after its done and I have heard of guys getting 3-5 more gallons out of their mills which is awesome for the price. Brain you beat me LOL.
TT MT4G3 all tricked
TTST4G3 MT4ed out
JR servos Hitec servos. Gens ace lipos KO radio.
malik is offline   Reply With Quote
Old 03-17-2009, 10:06 PM   #4
Location: 4373 Creek Road Chaffee,NY 14030 USA (716)783-5198
Trader Rating: 23 (100%+)
Default RayAracing reconditioning-resizing
There is a few threads running on the subject here on rctech. You can pic up some info on my website. Search here and use google search and you will find lots and lots info you need. Good luck friend. RayA
RayA is offline   Reply With Quote
Old 03-17-2009, 11:01 PM   #5
houston's Avatar
Trader Rating: 91 (100%+)
raya is the best in the best in the biz , period . he kind of invented a true resizer
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 03-17-2009, 11:12 PM   #6
Jaz240's Avatar
Trader Rating: 52 (100%+)
you grab your engine's butt and you pinch it!! Your engine gets really embarrassed and performs better for about 2-3 more gallons then it forgets how embarrassing it was to have its ass pinched and it starts acting funny again, so you pinch its butt again and remind it..it works maybe 2-3 times and then it dies of mortal embarrassment!!
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 03-17-2009, 11:29 PM   #7
+1
Brian Carey
615-838-5373
Old 03-18-2009, 02:08 AM   #8
OfnaJoe's Avatar
Trader Rating: 58 (100%+)
It's what you do to it on St.Patricks day if it's not wearing GREEN !
No really like they said, it prolongs your engine life, just be sure to check your crank pin to make sure it's not worn out. Ray A has a great site for more info, I am sending him mine when it needs it!
OfnaJoe is offline   Reply With Quote
Old 03-18-2009, 09:35 AM   #9
Default alloy reconstruction
Yes, pinching is a term best used discribing what we do with a cute but on st patys day. LoL. Rayraciing methode sleeve resizing is done with a Die designed by myself over 7 yrs back. My tooling Is operated by a small press, the press does not do the job, the die set does.in theroy the sleeve alloys are reconstructed to a smaller state to accomidate piston wear. I personally hold tollerances less than 1 tenth of one thousandth of one inch.
I loved the but pinching comments. Hehee
Old 03-18-2009, 12:09 PM   #10
ehames005's Avatar
Trader Rating: 74 (100%+)
That is great LOL
Thank you to my 2017 supporters:
Sworkz--Amainhobbies.com---ProTek Rc---Huston's Engine Service
ehames005 is offline   Reply With Quote
Old 03-18-2009, 01:02 PM   #11
CHogle's Avatar
Send a message via MSN to CHogle
look up O.S rocket racing here in Ohio. he is the best around period.
however just think about a conecting rod no matter who you have pinch your engine. if you increase your compression on a weak connecting rod it will fail.
C.HOGLE
Serpent America, Novarossi, O'Donnnell fuel, PT Racing Oils, SMC, H-bomb Designs, Stick it 1 racing, Motor Savor Filters, Fastraxx Hobbies
CHogle is offline   Reply With Quote
Old 03-18-2009, 04:43 PM   #12
22Racer's Avatar
Trader Rating: 67 (100%+)
Ofna Joe has a good point, if your crank is worn the motor will not last. I get alot of engines to rebuild and the crank is worn realy bad.
Pinching a sleeve really isn't a band aid, if all the internals are good you can get twice the life or more out of the motor.
Rex
Rw modding and engine repair http://www.rw-mods.com
Sleeve resizing $15.00/ motor rebuild $30.00
Argus engine distributor/Avid bearings/ Alpha engines/
Fx Royal engines/ Maxy Engines
e-mail rwmods@yahoo.com Rex Welch
22Racer is offline   Reply With Quote
Old 03-19-2009, 01:37 AM   #13
Default Rayaracing
I used rayaracing before and have to say that his work is smooth. Easy to work with and you can get the amount of pinch you want whether it's a tight fit or medium which I prefered since that would put less stress on the crank pin and con rod. I think rayaracing still offers his services on ebay and the price is very reasonable.
But before you pinch a motor, like it stated above you gotta check the other internals of the motor first to see if it's worth to rebuild the motor or just go get another.
HB D8T with BCE Chassis, ACE Shock towers and motor mounts, M2C Rear Suspension system, KH front steering plate and chassis braces, Lunsford Ti-turnbuckles & hinge pins, OS Speed motor, Hitec 5995TG steering, Futaba 9351 throttle/brake, OS 2060 pipe, and J concepts Punisher Body.
HB D8: CEO Mods Novarossi P5K with JP4 tuned pipe, JR 9000T steering, JR 8800T throttle.
gotspeed_2000 is offline   Reply With Quote
Old 03-19-2009, 09:43 PM   #14
pitpop's Avatar
If your engine idles and performs ok, you don't want to pinch it. The first one or two gallons of your engines life is spent getting RID of the pinch. Once the seal is matched between piston and sleeve, it should run for a very long time. The number one caindidate for a sleeve pinch is an engine that sucked dirt. In that case, normally the internals are good, but the p/s seal is ruined. Good luck on your decision, but with us, we wear out the bearings and such before the p/s.
Cody King's Wrench (and dad :))| Team Kyosho International | Reds Racing Engines | Pro-Line Tires
KO Propo | Byron Fuels | AbsoluteHobbyz.com | Stickit1 Racing | kustomrcgraphics.com
LiveRC.com | OCRC Raceway | codykingrc.com | ROAR Sanctioning Director
pitpop is offline   Reply With Quote
Old 03-21-2009, 07:38 AM   #15
Good points made Pitpop, although 1 thru 2 gallons seems long to loose engine pinch. 1/2 gallon Is reasonable on new,and a resized half that and the piston + sleeve should be in its sweetspot so to speak.
Espicialy good point with dirt contamination.9 out of 10 sets from my customers require liner + piston surface finish conditions improved to establish good seal. In my experience in most all cases a pinch is not enough. By the amount of work I receive each day/week I see most racers now agree.Just pinching went out with the twist.LOL
RayAracing.
"the tuning bible" houston Onroad Nitro Engine Zone 311 04-24-2017 11:18 PM
STS engines sparksy Onroad Nitro Engine Zone 2774 02-03-2013 06:05 AM
Yay Dvx400Rider Nitro Off-Road 7 02-27-2009 08:25 PM
Fantom Engine Manual = ABC Engine Bible Horatio Monster Trucks 9 02-05-2007 07:35 AM
