Old 03-17-2009, 12:53 PM   #1
ace921000's Avatar
Default choosing a proper glow plug
I noticed my hyper 7 tq sport kinda has a high idle after I give it the brakes. The car was running pretty rich when I ran it last and I had the idle turned down as far as it could go without the car dieing when giving it the brakes. So my question is can a improper glow plug cause your idle to be funky? My car has the standard hyper .21 3 port engine in it. To be honest I don't know what kind of plug I was running in it. What should I be running? Should I get a cooler plug? Thanks.
ace921000 is offline   Reply With Quote
Old 03-17-2009, 12:57 PM   #2
Location: I live in the middle of nowhere. A place where we have roughly 0 nitro tracks, on or off road. All we have is flat grass and open corn fields, sometimes it's not even fun to bash there anymore.
not really, a glow plug is really just to start the car
HPI MT2 G3.0
OFNA Hyper 7
LOSI 1/18 Mini Desert Truck
Nothing for on-road, all we have out here is grass and cornfields.
Now i just need to find a track so i can race!
murdermode is offline   Reply With Quote
Old 03-17-2009, 01:01 PM   #3
guambomb's Avatar
i would check out the clutch cause if it stalls when you hit the brakes your clutch/spring may be bad.
guambomb is offline   Reply With Quote
Old 03-17-2009, 01:07 PM   #4
ace921000's Avatar
oh no it doesnt stall now. it only stalls when i turn the idle down too low using the idle screw. im just going to mess around with it today and see what i can do
Old 03-17-2009, 03:26 PM   #5
pitpop's Avatar
If your engine uses a standard (non-turbo) plug, the MC-9 should work great. It's pretty much the bench mark standard for glow plugs, plus it's easy to find. The plug can definitely have an effect on the idle. If the plug element is getting white, and especially if the coils are crunched up or sucked down, it will effect the engine. If you want that perfect tune, use a fresh plug. It sounds to me like your bottom end is fat, and you need to lower the idle, but still put a new plug in before fine tuning.
Cody King's Wrench (and dad :))| Team Kyosho International | Reds Racing Engines | Pro-Line Tires
KO Propo | Byron Fuels | AbsoluteHobbyz.com | Stickit1 Racing | kustomrcgraphics.com
LiveRC.com | OCRC Raceway | codykingrc.com | ROAR Sanctioning Director
pitpop is offline   Reply With Quote
Old 03-17-2009, 03:39 PM   #6
rearviewmirror's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rearviewmirror Send a message via Yahoo to rearviewmirror
What?
ARCTIC DOG RACING (Nitro free since 2009)
"Straights are for fast cars, curves are for fast drivers...."
8ight-E / 8ight-TE / T4 / Slash
rearviewmirror is offline   Reply With Quote
Old 03-17-2009, 04:28 PM   #7
bjr48's Avatar
Originally Posted by rearviewmirror View Post
What?
Oh yeah, it's true! Once I get my engine started I like to take the plug out. They last a LOT longer that way!
bjr48 is offline   Reply With Quote
Old 03-17-2009, 04:31 PM   #8
brentmorl's Avatar
rule of tumb is the higher percentage fuel you use a colder plug 30% cold-20% hot
ST-RR
LST2
AD-1
brentmorl is offline   Reply With Quote
Old 03-17-2009, 04:32 PM   #9
Not with Go engines, they run an hot/ultra hot plug even with fuels at 30%. It all really depends though.
Old 03-17-2009, 06:06 PM   #10
ace921000's Avatar
thanks for the replies guys. i have the issue resolved.
Old 03-17-2009, 07:03 PM   #11
8scaleracer2006's Avatar
Default glow plug
i use a MC-59 in my axe roosi lsk works just fine,should be good plug for you.
Soar - Dialed Hobbies - Novarossi - Hobbywing - Futaba
8scaleracer2006 is offline   Reply With Quote
16% 20% 25% Nitro content??? Nitro-Racer* Nitro On-Road 24 05-26-2009 11:02 AM
Engine Help Please! :( Dragon Nitro On-Road 45 09-06-2005 09:44 AM
