Old 03-17-2009, 03:27 AM   #1
Default Ace 1015 issue
Hi, I need to ask a question for the more experenced.I have a couple of ace 1015 servos and one (throttle) keeps twitching.Ive had it for a while.I thought It might be the bind i did for my new car because I dont think it was doing it on the old car.
I put it in another car and its still twitching with a different reciever.I tried binding it 5-6 times and it wont stop It even does it plugging it into the steering port.The wireing looks ok and the bottom of the circuit board looks good.
Has anyone experenced this and no how to fix it of is the servo all over?
JB 28 is offline   Reply With Quote
Old 03-17-2009, 03:46 AM   #2
TIX
TIX's Avatar
Trader Rating: 17 (100%+)
check all the gears. one may be starting to wear and causing slop. the slop will cause it to constantly correct itself.
i also found that the very last gear which is plastic can wear quickly sometimes
Alan Nankervis.
TIX Race Designs. Plaig Bearings. Thunder Innovations
TIX is offline   Reply With Quote
Old 03-17-2009, 04:16 AM   #3
Lonestar's Avatar
The pot is dead...
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 03-17-2009, 04:53 AM   #4
All gears look good.and horn turns smoothly.Its not a constant twitch.When i was setting it up on the new car apart from the twitching it forgot its preset settings a couple of times.but in the old car it apears to just twitch where its the only servo that does even after swapping some around.I dont think its the radio because its spektrum.
Does the servo have a memory circuit in it or is that all radio?
Old 03-17-2009, 05:05 AM   #5
Default top of the case
the plastic top case is where the play is coming from.when ever the little gear post have play in them the servoo is constantly looking for center.8.00 at a main,problom solved.the new case has metal bushing in them so it should last.
smash8ight is offline   Reply With Quote
Old 03-17-2009, 07:20 AM   #6
BIG RE's Avatar
Trader Rating: 32 (100%+)
this is it, replacing the case gets rid of it 99.9% of the time
BIG RE is offline   Reply With Quote
Old 03-17-2009, 02:03 PM   #7
Integra's Avatar
another reason i wont trust Ace/Ae servo's EVER again on my race rigs.
Old 03-17-2009, 03:00 PM   #8
Scottmisfits's Avatar
It could also be the gears inside. If it has some time on it, you may want to rotate the gears. This way it has fresh gear on fresh gear and takes the slop/twitch out of it.
Any servo will do this after some time. Any experienced RC person will know this. And it is a piece of electronics, sometimes the servo's just puke out.
I have an Ace servo, a 1015, that has 2 1/2 years of 1/8 buggy on it. It's now in my crawler and still holding up. It's been in my crawler for almost a year now. Some people will like certain things, some people won't. I will never trust a hitec servo in my rigs again for steering or throttle. Some people will never like the Ace/AE stuff? Anything wrong with either of them? No. Just different opinions.
Scottmisfits is offline   Reply With Quote
Old 03-17-2009, 03:27 PM   #9
BIG RE's Avatar
the cases have been upgraded, the gear pins used to go straight into plastic, now they seat into bronze bushings and are every bit as reliable as other servos
Old 03-17-2009, 03:39 PM   #10
Integra's Avatar
still wont trust them...ive seen JR's which are brass retained and they still did the same thing....i have yett to see a Hitec Ti gear set or Top case fail.
Old 03-17-2009, 08:33 PM   #11
BIG RE's Avatar
JR's are pieces of crap, I'm with you there, every one that I have ever had, or seen other people have, had issues. But, almost everyone here who has had Hitec's (although not many of the new ones because nobody trusts them anymore)burned up the circuit board and had runaways. My first choice is Futaba, but with the new cases I think the ace servos are just fine.
Old 03-17-2009, 08:46 PM   #12
Integra's Avatar
i have never seen a 5955 or 79XX fail to date.....i was screwing around with the Ace's when Hitec was having issues with their original boards in the 5955's....and i jumped on board with hitec after i couldn't keep a gear set in the Ace's and Magically a 5955 puts up with it where the ace was failing one after another...I do have a total of 6 1015's btw and i just dont trust them in my race gear anymore..bashers Sure...i got all the time in the world to change out junk on my Own time.
Old 03-17-2009, 08:58 PM   #13
And yet I can keep an original Ace 1015 for this long? Let me guess Nick, you drive Losi's?
Old 03-17-2009, 08:59 PM   #14
Integra's Avatar
Common Scott you should know that.
they actually started to fail at the 06 nats in my CRT..so the losi's are moot point
Old 03-19-2009, 08:17 AM   #15
rcgeezer's Avatar
So, if I understand correctly, the new Ace servos now come with the upgraded cases? I'm getting one shortly and want to be sure I don't need to purchase the upgraded case as well?
**Team Terribles Northern CA Regional Rep.**
Cold Fusion R/C Products Team Driver
Answer-RC USA / Team Sweep Racing USA
Team RcRenew...visit us at rcrenew.com!
Triton RC Alpha Plus Engines
rcgeezer is offline   Reply With Quote
New XRAY 808 Philipm Nitro Off-Road 12372 12-08-2015 06:43 AM
Losi Truggy rcfreak24 Nitro Off-Road 1884 12-27-2009 12:53 PM
Top rated steering servo for 1/8 truggy xxxtcr Nitro Off-Road 33 07-12-2009 07:51 PM
best steering servo for my rc8? CaptainHowdyt13 Nitro Off-Road 19 02-08-2009 08:43 PM
What Throttle SERVO Are You Running robbdny Nitro Off-Road 30 11-17-2008 10:17 PM
Recommended steering servo? BradT041 Monster Trucks 29 03-27-2007 11:44 AM
