Old 03-21-2009, 11:10 PM   #31
malcnz's Avatar
Originally Posted by Integra View Post
Plastic horns are weak to say the least....they WILL break at the most opportune time and WILL take you out of a race.....be smart and run an alum horn and to be double smart beef it up with a small strip of CF....ive seen my fair share of tweeked, bent, broken and mangled servo horns over the years.
I to have seen some funny things happen to servo horns over the years and have seen both plastic and alloy horns have issues...I would rather use the supplied good quality plastic servo horn..in fact it has an alloy brace around its base to stop it from stripping.. on an ace servo than an ill fitting futaba horn on an ace servo.
also set youre epas, set youre servo saver correctly and you should be good to go.
SCHUMACHER MI5 EVO/TEAM POWERS/SANWA/DX4R PRO.
SERPENT F110/TEAMPOWERS 21.5.
LOSI 22 2.0/TEAM POWERS 8.5
malcnz is offline   Reply With Quote
Old 03-22-2009, 08:02 AM   #32
Integra's Avatar
Old 04-27-2009, 12:05 PM   #33
When i bought my 1313 i picked up a kimbrough saver and when i finally went to mount it i was amazed with the amout of slop between the insert and the servo spline. awful. Almost like how i run my play in the gear mesh!
Anyways i tried the smaller kimbrough futaba specific saver and it fit similar to the first. Frustrated I decided to order an Associated saver for it and it fit perfect!
http://www3.towerhobbies.com/cgi-bin...?&I=LXFUL0&P=7
Hopefully i will have good luck. IDK maybe i just got a bad batch of kimbroughs. But i had bought one in the past and it fit considerably better.
Driving the tmaxx
boomerrw is offline   Reply With Quote
New XRAY 808 Philipm Nitro Off-Road 12372 12-08-2015 06:43 AM
Losi Truggy rcfreak24 Nitro Off-Road 1884 12-27-2009 12:53 PM
Top rated steering servo for 1/8 truggy xxxtcr Nitro Off-Road 33 07-12-2009 07:51 PM
best steering servo for my rc8? CaptainHowdyt13 Nitro Off-Road 19 02-08-2009 08:43 PM
What Throttle SERVO Are You Running robbdny Nitro Off-Road 30 11-17-2008 10:17 PM
Recommended steering servo? BradT041 Monster Trucks 29 03-27-2007 11:44 AM
