Old 03-16-2009, 03:38 PM   #1
DTM_Motorsports's Avatar
Default header to pipe connection help
Ok, I know I'm not the only one who has trouble keeping the pipe
inside the rubber piece between the pipe and header.
Zip ties on, everything tightened up and such, but still sometimes
the pipe will come out ...... dangit !!!!
-=A=-
Richardson Tx.
Mugen MBX5R with RB WS7 engine
Traxxas Rusler with 2.5
Cen Magnum NT
DTM_Motorsports is offline   Reply With Quote
Old 03-16-2009, 03:47 PM   #2
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Ok... your BEST option is to get a "1 piece" pipe (it is still 2 pieces, but it has the same type of flange as connects to the back of the engine, with the same "pipe grommet" or whatever you call those... and 3 little springs.)
Barring that... flare the end of the pipe and the end of the header a bit (you can do it with a flaring tool... but you can also use needle-nose pliers or a screwdriver) Just a little... enough to give the zip ties something that they can't expand over so it won't come off as easily. Not perfect, but it will help some.
Pipes can be had cheap... several decent ones are available for the $50-60 range brand new... used can be less. Ask around.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 03-16-2009, 03:48 PM   #3
imaxx21's Avatar
Send a message via AIM to imaxx21
exactly why racers use 'one piece' pipes...
back the tmaxx days i used to use hose clamps
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 03-16-2009, 06:29 PM   #4
I figured there had to be some that attached like the header does to the motor.
Just have not even started to know what brands, types, or other factors
to use in my search.
I'm not even sure what would be the better choice in pipes for my car
I got the S7 II in it running 30%
What else factors in when choosing a pipe?
I prefer low to mid range power since there really isnt a lot of time for
full speed on the track.
-=A=-
Richardson Tx.
Cen Magnum NT
Old 03-16-2009, 07:16 PM   #5
If low-mid end power is what you're looking for then try a Dynamite Hard Coated 053 pipe set for about $50.
Losi-Runner is offline   Reply With Quote
Old 03-16-2009, 07:26 PM   #6
chunk t's Avatar
DTM,
I only run the two-piece header/pipe combo with silicone coupler. I like the ability to make pipe length adjustments at the race. Couple things you can do to keep everything together.
1. clean out the oil from inside the coupler before attaching the pipe & header.
2. use a course 120 grit paper or metal file and rough up the O.D. of the header & Pipe
3. use a pipe cutter and carefully score the O.D.
4. use a cable puller to get the zip-ties tight. Finger tight will never hold.
Like I said, I use two-piece for my trucks & boats. Having an extra +/-1/4" of adjustabiliy in the exhaust length can help you find the engine's sweet spot at the track.
chuck "chunk" thomas
1:10, 2-wd Stadium Trucks
B-Mod Tunnels
If ignorance is bliss... I must be in heaven!
chunk t is offline   Reply With Quote
Old 03-16-2009, 08:02 PM   #7
Quickest way to keep'em together is like Dom said.Stick a philips screwdriver in the hole you want bigger roughly about 3/4" then just roll the screwdriver around 10-15 time mith light to med pressure.What you want to have happen is the lip the screwdriver is touching will gradually bend out smoothly so it looks like the end of a trumpet or saxamaphone or clarenet.If the end turns out looking like a skin flute you did something really wrong. Also use all of chucks advise.I had never heard of the pipe cutter method but sounds like another way to achive what I used to do with a deburring knife.
butch man is offline   Reply With Quote
Old 03-16-2009, 08:11 PM   #8
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Just buy a 1 piece spring coupled pipe and be done with it. Dynamite hard coat 053 would be perfect as already stated. For $50 you can't beat the quality/ preformance of these pipes. Most likely you wiull get a big increase in preformance by going to a racing style pipe. Those cheap silicone coupled pipes usually don't preform well at all.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 03-17-2009, 07:25 AM   #9
Akhor's Avatar
+1
The racing pipes just seem a tonne better, for pretty much the same price.
Also, I think the recommended pipe for the RB s7 is the RB 2046.
--Blaine--
VBC D07, VBC D08
Mugen MBX 7, Mugen MBX 7 Eco,Mugen MBX 7r, Mugen MBX 7r Eco
www.rcgears.net, www.carcar.ca, www.karz.ca
Akhor is offline   Reply With Quote
Old 03-17-2009, 08:34 AM   #10
Thanks for all the advise, think for now I'll start shopping for the
Then at least I'll have a better point of reference
thanks !!!
-=A=-
Richardson Tx.
Cen Magnum NT
Palmaris engine thread EdwardN Onroad Nitro Engine Zone 2533 08-12-2013 10:48 AM
New Hot Bodies Buggy!!??????? monsteraddict Nitro Off-Road 14489 03-18-2013 01:42 PM
silicone pipe/manifold tape bsmooth Nitro On-Road 8 02-15-2008 08:26 PM
Fuel not getting to the carb Mann2006 Nitro On-Road 40 12-20-2006 06:46 PM
