Old 03-12-2009, 07:34 AM   #16
rc-mike's Avatar
Originally Posted by mfrosty View Post
OK, I cleaned it with both plastic safe contact cleaner and denatured alcohol, blasted it real good with my air compressor then lubed the shit out of it with after run oil. Worked it around really good by hand. Everything feels smooth, no grittiness or anything. Keeping my fingers crossed
That's about all you can do at this point I think. If everything looks good I'd just run it and see how it does.
rc-mike is offline   Reply With Quote
Old 03-12-2009, 07:35 AM   #17
rc-mike's Avatar
I have a proline one sitting around that's going on this thing. Screw that RC8 filter.
Yeah, throw it as far as you can.
Old 03-12-2009, 07:40 AM   #18
amdmoto's Avatar
It sucks you had to learn the hard way but we all have to start somewhere, I would just make sure that you always have a good oil up air filter on there, and when the conditions are dusty the air filter needs to be change very often.
amdmoto is offline   Reply With Quote
Old 03-12-2009, 07:41 AM   #19
mfrosty's Avatar
Trader Rating: 14 (89%+)
Definately seems to have lost a little bit of it's compression. I'm going to fire it up here in a few (car's in pieces from cleaning up after yesterdays run). If it runs I'm going to have it pinched. $15-$20 is a hell of a lot easier to swallow than the cost of a new engine.
~TQ Racing~O.S. Engines~AKA~Answer R/C~
http://www.youtube.com/user/frostyone1977
mfrosty is offline   Reply With Quote
Old 03-12-2009, 07:42 AM   #20
amdmoto's Avatar
Hey rc mike have you ever raced at milan or at the track in white house?
Old 03-12-2009, 07:46 AM   #21
Trevor Williams's Avatar
Trader Rating: 195 (100%+)
preventetive maintenance on air filters is VERY important. You must inspect/replace EVERY time you run, dusty or not, just do it. YOU MUST KEEP A WELL OILED FILTER AT ALL TIMES. The AE rc8 airfilter is fine, no need to change it, just pull the zipties tighter next time, and make sure its cinched in the right locations. It sucked dirt in that area due to a poor seal, not because of the AE airfilter, the AE airfilter is fine.
ALSO MAKE SURE THE FILTER IS ALIGNED IN THE PROPER DIRECTION, IF NOT THE LID WILL KNOCK IT LOOSE A PINCH OR TWO AND YOU WILL SUCK DIRT LIKE CRAZY, IT HAPPENED TO A FRIEND OF MINE
RC10-B6d | RC10-B64d
SmacTrac
#WeAreAE #ReedyPower #AE4Life
Trevor Williams is offline   Reply With Quote
Old 03-12-2009, 07:53 AM   #22
Trader Rating: 52 (100%+)
I have had this happen. the fine dirt particals actually sanded the piston and I lost compression. the bearings were ok luckily, so I sent he piston and sleeve to OSROCKETS and within a week good as new. I wouldnt say the motor is trash just might need a little work thats all.
MO
Mo Denton-www.mnkraceway.com
Team Losi
Proline,-Redrock Hobbies-,VP Powermaster fuel,Darkside Designs,Speedy Bills!
fast for an old guy
Mo Denton is offline   Reply With Quote
Old 03-12-2009, 08:00 AM   #23
TTR:EB4's Avatar
i can see exactly where the dirt got in there
circuled in red, you can see the dirt around that area in the big red circle, and in the small one you can see where the filter has been tucked in too much
The Masher! >.<
TTR:EB4 is offline   Reply With Quote
Old 03-12-2009, 08:08 AM   #24
SmacTrac
Old 03-12-2009, 08:10 AM   #25
GregH's Avatar
Send a message via AIM to GregH
I don't think it got past the zip tie at the neck. Definitely got past the filter element. Use grease on both sides of the filter that mate up to the housing.
GregH is offline   Reply With Quote
Old 03-12-2009, 08:23 AM   #26
mfrosty's Avatar
I'm using the Power Save elements and I think that's where the real problem is. They don't even fit right
As you can see from AE's instructions the inner one should be taller, which is not the case on the PS ones
Power Save owes me a new freaking modded engine
And the neck is taken care of
Once that RTV cures I'll zip tie it.
I'm using 2 of the power save inner foams now
Old 03-12-2009, 08:27 AM   #27
my power save elements are a very good fit, there are no gaps at all like the first picture you posted, they fit side to side with no dead space. That looks like its been cut or something? The proportion of that inner element is all wacked out bro.
Dude, whatever those are you are using for inner elements are incorrect.
this is what the power save rc8 inner elements look like:
SmacTrac
Old 03-12-2009, 08:37 AM   #28
mfrosty's Avatar
That came NIP Part # P-06241
Anyone know if they're members of this site? I have a SERIOUS bone to pick with them!
Old 03-12-2009, 08:41 AM   #29
chickenfarmer's Avatar
+1 on the powersave. I used them forever on my rc8 and they were perfect. You have something on wrong as mine NEVER looked like that.
WWW.FASTLANEGEAR.COM for all your "pure custom" rc pit needs.
Thanks to: Team Losi Racing, Fastlane GraphiX, Sidewinder Fuels, OS Engines, Lucky 7 RC Products
chickenfarmer is offline   Reply With Quote
Old 03-12-2009, 08:42 AM   #30
mfrosty's Avatar
Mine don't even have the holes in them, I had to cut them myself.
Rc10ntc3 Taz_S Nitro On-Road 9437 05-28-2017 08:13 PM
Palm Beach County south county park edm rob Florida Racing 2392 01-02-2012 06:38 PM
Air filter rockfordccinc Nitro Off-Road 32 09-13-2009 08:32 AM
Yay Dvx400Rider Nitro Off-Road 7 02-27-2009 08:25 PM
