Old 03-24-2009, 02:09 PM   #76
mike williams's Avatar
Trader Rating: 45 (100%+)
Originally Posted by GMS_Racing View Post
Ok i have two questions..may be kinda dumb but here goes. Anyone have and tips to gettin the Losi stickers off the box. I tried and they shred to tiny pieces. Next one is what is "wet noodle"?? kinda of wire??? thanks
good luck with the stickers, I used a 4 1/2" grinder with a wire wheel, but i also sandblasted and powder coated mine. maybe try goo-gone or something like that. As for wet noodle, yes it is a brand of wire. I believe all silver stranded wire, also very popular with racers.
LOSI MF2 ....... too fast for me!!!!!!!!
mike williams is offline   Reply With Quote
Old 03-24-2009, 05:10 PM   #77
Integra's Avatar
a heat gun works 99.9% of the time on decals...just peel slow and even...mine came off no problem's.
Old 03-25-2009, 08:54 PM   #78
jrr102486's Avatar
Send a message via MSN to jrr102486 Send a message via Yahoo to jrr102486
wet noodle wire is made by deans.
anywho, i have had my starter box here now for 2 weeks, and i have gone thru 3 sets of motors in it already.
what is my "best" solution on fixing this problem? i have heard to use traxxas e-maxx 550's saw here in the thread of someone using ofna 775's
just want to solve my problem before nitro season really starts here in wisconsin hopefully.
thanks
josh
Josh Riese - 2002 Subaru Impreza WRX (212whp/223trq 12psi no tune!)tuning stage 2.5 @25psi
jrr102486 is offline   Reply With Quote
Old 03-26-2009, 06:20 AM   #79
looneytune's Avatar
Trader Rating: 23 (100%+)
If you are only running one class, get the OFNA truggy start box. If you are running buggy and truggy, get the OFNA box.
Take the internals from the OFNA box and install them in the Losi box. End of problems. I fought with that Losi box for a whole summer until I fxed it with the OFNA 775 motors and internals. All you need from the OFNA box is the complete bulkhead assembly with motors, wheel, belt and idlers. It may be cheaper to order just those parts from A Main than buying the box complete. A little modification to the cage to move the wheel a bit and your done. You won't regret doing it.
Losi 8ight T 2.0 Novarossi P5XS
HPI Baja 5T
looneytune is offline   Reply With Quote
Old 03-26-2009, 06:40 AM   #80
Integra's Avatar
wow 3 set's of motor's....what are you doing to the darn things ?...what kind of battery are you using ?
Old 03-26-2009, 09:38 AM   #81
jrr102486's Avatar
im runnin 2-6000mah maxamps 7.4v lipos wired in series. at first it was just on my new grp, in which i got that figured out (heat it up to at least 180 and then try). then when i went to run my truggy down at leisure hours in joliet this weekend it crapped out on me again and it was maybe 1-2 bumps then white smoke from the sb chassis.
Old 03-26-2009, 09:44 AM   #82
Integra's Avatar
Imo you got too much power goin to the motor's...and they are takin a dump.
Old 03-26-2009, 09:57 AM   #83
jrr102486's Avatar
too much power? whats that?
i thought that it was supposed to run at 14.8v for the setup, so why would 2 lipos be giving it too much power than 2 stick packs in the same setup?
Old 03-26-2009, 11:10 AM   #84
Integra's Avatar
Race stick pack's have ALOT higher discharge rate and are capable of feeding the motor's Alot more Amps then then can handle...and they Puff.....a Single 4 cell lipo isn't as powerful "PERSAY".....what C rating are those Maxamps packs ? 30c ?
Old 03-26-2009, 03:56 PM   #85
jrr102486's Avatar
they are the older 20c 2s2p 6000mah soft case packs.
Old 03-26-2009, 08:35 PM   #86
Integra's Avatar
Im still thinking they are too much.....especially for the stock losi motor's....a pair of Traxxas Titan's might have a better shot at lasting....you could also venture into some 775's.
Old 03-26-2009, 10:25 PM   #87
Will the Traxxas Titan's bolt wright in place of the stock motors.
RONNIE C is offline   Reply With Quote
Old 03-27-2009, 07:14 AM   #88
Integra's Avatar
they are a plain old 550 can...so yes they will...you will need to tap and drill a new set of pinion's tho to install onto the Titan's.
Old 03-27-2009, 07:20 AM   #89
jrr102486's Avatar
wouldnt you also have to cut the shaft to length to clear the wheel on the one side?
Old 03-27-2009, 07:31 AM   #90
Integra's Avatar
umm no.
Losi Truggy rcfreak24 Nitro Off-Road 1884 12-27-2009 12:53 PM
FS: Losi RTR Starter Box with two 3600 mAh Batteries - anodized blue Garet Jax R/C Items: For Sale/Trade 14 08-20-2009 06:53 AM
starter box,tools, servo & lipo charger fstnv1 R/C Items: For Sale/Trade 17 08-13-2009 11:15 AM
I am looking to buy a 1/8 buggy RGraves R/C Items: Wanted to Buy 13 10-05-2008 04:32 PM
losi 8ight and 8ight-T starter box for sale jqtopa R/C Items: For Sale/Trade 8 08-27-2008 05:23 PM
Team Losi Eight Truggy ffpm46 R/C Items: For Sale/Trade 6 11-29-2007 05:28 PM
Team Losi XXX-NT Matt M. R/C Items: For Sale/Trade 11 03-14-2003 11:20 AM
