Old 03-14-2009, 06:28 PM   #46
Hey guys, I am having some problems. It seems this motor is extremely tight and will hardly turn over even after I heat it up to 200 degrees(non-tuned grp). Is this normal?? Also it seems after I heated the engine to 200 it seems when I tried to prime it the fuel would evaporate instantly when it first entered the carbeurater leaving airbubbles in the line and not letting gas in. Is this normal? What should I do?
rgrassey@me.com is offline   Reply With Quote
Old 03-14-2009, 06:39 PM   #47
mike williams's Avatar
Trader Rating: 45 (100%+)
i personally blow into the pressure line to prime, i do not use the box to prime. I have heard some people have to loosen up the glow plug to get their motors started then tighten after it fires. I personally have never had this problem. GOOD LUCK!!
LOSI MF2 ....... too fast for me!!!!!!!!
mike williams is offline   Reply With Quote
Old 03-14-2009, 06:45 PM   #48
Integra's Avatar
you heated the carb too much.....take special attention to Not heat the carb so much and it should take fuel no problem's....a Tight motor is normal...nothing outta the ordinary there.
Old 03-14-2009, 07:41 PM   #49
ok great, I got it started once and on the box it idled nicely and plenty of smoke but then it died when I put it down. Should I lean the lsn a bit?? Also I think I am having trouble getting it to fire because the fuel is evaporating before I get it started so hopefully I get that stopped and it will be good. Also will ha gell cell have alot more power than 2 stick packs?
Old 03-14-2009, 08:40 PM   #50
Does anyone know if the gell cell will have a noticeable amount of mor power than 2 3000 mah stick packs?
Old 03-14-2009, 08:53 PM   #51
Integra's Avatar
stick packs will have more on initial charge...but a gel will last longer then 2 3000's.
Old 03-14-2009, 08:53 PM   #52
xDaRReLLx87's Avatar
Originally Posted by Fletcher6371 View Post
OK this may sound dumb but would a lower VOLT battery be better than a Battery with a higher Amp (C*mAH/1000)? for instance is a 7.4v @ 5200mAh 25C (130amp) better than a 14.8v @ 2200mAh 20C (44amp)? I'm thinking the 14.8v is better but still not quite sure? thanks again guys.
I don't think that Lipo's are a great idea for a starter box. whats the point of a lighter battery that can catch on fire when all your doing is starting cars
I can see it now, "come on damn thing start" wufffghhh your cars in flames
I would stick to the 12V cell but then again that's just me. You wouldn't have to balance your starter box If you want safe light betteries theres always a123 (LiFe) batteries which are 3.7v p/cell insteald of 4.2v (Lipo)
both are lithium just one is safer and doesn't need to be balanced often at all while the other one can't and not only that but you can drain all the power from a123's just my opinion
Hyper 9E 2000KV T8/RX8- 4S Turnigy 4500 mah
Ko ProPo EX-1 UR 2.4 ghz, Hitec-7950TH
xDaRReLLx87 is offline   Reply With Quote
Old 03-14-2009, 09:11 PM   #53
Integra's Avatar
Dead As in beyond safe discharging rates a lipo does not catch fire....it will puff up and become worthless....they catch fire when they are dead shorted....and or charged at a rate more then what they are rated for.
Old 03-14-2009, 09:12 PM   #54
Would you recommend spending the 30 bucks for a gell cell or just sticking with my stick packs?
Old 03-14-2009, 10:31 PM   #55
Integra's Avatar
i would spend the 30 on a ebay lipo and or start saving for a decent lipo charger so you can forget about having battery issues forever....lipo makes everything soo much easier imo.
Old 03-15-2009, 02:08 PM   #56
+1
Gel cells are heavy and have a fairly short life. you constantly have to keep them charged without over charging. lipo's are the only way to go. Just have to keep an eye on them!!!
Old 03-15-2009, 04:27 PM   #57
Ok, I am going to just start saving up until I get a decent amount of money to spend and just get all the little stuff I need and I may incorpoate a lipo into that.
Old 03-15-2009, 05:27 PM   #58
GoJohnnyGo's Avatar
Trader Rating: 19 (100%+)
Cool Well............
Well........I stuck 2 of the Ofna 775 motors in my Losi box.....rewired with wet noodle and it starts anything...LMAO....and will start 2 Truggies and 2 Buggies all day long ......Its the Cats Meow!!!!
>JOHNNY<
O'Donnell Racing
AKA Tires
Z-RACING *Upgrade RC* KAL-GARD* BOCA Bearing*
GoJohnnyGo is offline   Reply With Quote
Old 03-15-2009, 05:33 PM   #59
Integra's Avatar
they fit the stock losi cage ? pics would be appreciated
Old 03-15-2009, 05:56 PM   #60
GoJohnnyGo's Avatar
Cool Sheeeeeeeeeeesh
Seeeeeeesh...LOL...I knew that was going to be asked...lmao..I'll see what I can Do....charge camera.....might take me a few days tho....busy around here.!!!
>JOHNNY<
O'Donnell Racing
AKA Tires
Losi Truggy rcfreak24 Nitro Off-Road 1884 12-27-2009 12:53 PM
FS: Losi RTR Starter Box with two 3600 mAh Batteries - anodized blue Garet Jax R/C Items: For Sale/Trade 14 08-20-2009 06:53 AM
starter box,tools, servo & lipo charger fstnv1 R/C Items: For Sale/Trade 17 08-13-2009 11:15 AM
I am looking to buy a 1/8 buggy RGraves R/C Items: Wanted to Buy 13 10-05-2008 04:32 PM
losi 8ight and 8ight-T starter box for sale jqtopa R/C Items: For Sale/Trade 8 08-27-2008 05:23 PM
Team Losi Eight Truggy ffpm46 R/C Items: For Sale/Trade 6 11-29-2007 05:28 PM
Team Losi XXX-NT Matt M. R/C Items: For Sale/Trade 11 03-14-2003 11:20 AM
