What is the best air filter in the market?
I run OFNA's air filter...but the dust and dirt keep entering the engine..my engine always dirty inside (black colored)...then I cleaned the inside until it's squeaky clean, but after first day run it turned black again...is this the air filter problem or something else? my air filter setup is: inner filter with oil and outer filter without oil.
Thanks in advance and pardon my english....
If you were sucking in dirt you would no compression at all. The black stuff in your engine is carbon build up. Some fuels leave it some don't Your fine with the ofna filter. if conditions are extremely dust oil up you outer filter and put an outer cover over that (available on ebay) and your good to go. You might want to change you prefilter through out the day of running to keep engine performance up.
what kind of fuel do you run? I have been running cold fusion fuel and just took the motor out to check the inside and its as clean as it was in the box. This is the best fuel I have ran in a while, keeps a great tune the temps are lower with it and keeps the engine clean.
