HELP! Engine sounds like its under water when I full throttle
HELP! Engine sounds like its under water when I full throttle! I'm not a newb in tuning engine but not an expert either. But this is just making my head ache like crazy! Low end is awesome! but WOT... sond like it's drowning under water. and when gas is half way through the tank, feels like it's leaning out or something....
engine is a .24 Trinity Extech w/ Bigboy Pipe.
ANy help would be appreciated!
Thanks!
Thanks!
yeah airleak..........hose...gas tank...
Sell it to me for 100$
See you sunday homie..
I bet your engine is overly lean on the highend. Sounding like it's drowning? I'd check the back pressure from the pipe through to the tank for leaks as the culprit for what you are experiencing.
Thanks ya'll!!!!
i was thinkin airleak too.... so.... I put some seals on my carb and the carb slide. and i'll see what happens. if it's still there, will probably hafta change fuel tank.... and will change glow plug as well just in case.
any more inputs will be very much appreciated!
Thank you all!
Thank you all!
air leak or too lean
if the seal are ok reset all the needles to factory setting and re tune and if can check the needle o-rings for any cracks or breaks .
bad glow plugs can cause all sorts of problems, if the engine started acting up out of the blue, that's my bet
check the simple things first
Thank you sir!!! Will run it today and see how it goes...
I always see you at Revrace... and Cody has been a big help to me. with spare parts support! hehe! Front arms.... cup joints... etc.... when Airland hobbies is out... you guys are awesome!
GUMBALL miss kita bruha ..lols
