Old 03-11-2009, 01:14 PM   #16
houston's Avatar
Trader Rating: 91 (100%+)
thats what i am saying is its probably not an ofna/jammin flywheel
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 03-11-2009, 01:16 PM   #17
houston's Avatar
dont you drive losi ???
how ya doin up there in canada ? winternats? did you go ?
monty
Originally Posted by Integra View Post
as far as i know...ofna flywheels are all the same....ive never heard of this 2.2 versus 2.0 thing.....there are different diameter ofna flywheels...but as far as i know the pin diam is all the same......here's a little chart from Mitch at M2C's site on what pin diam's fit which shoes.
he difference is the pin size of the flywheel it self. We have 5 different style clutch shoes.
Our clutch shoe styles are Mugen style, Kyosho style, Jammin style, Associated Style and the Losi 8ight style.
Here is a chart of the type of clutch shoes you should order.
Mugen flywheel = Mugen style clutch shoes
Xray flywheel = Mugen style clutch shoes
Kyosho flywheel = Kyosho style clutch shoes
Jammin flywheel = Jammin style clutch shoes
Hot Bodies flywheel = Mugen style clutch shoes
Cen flywheel = Mugen style clutch shoes
Ofna flywheel = Mugen style
RMV flywheel = Mugen style clutch shoes
Old 03-11-2009, 01:31 PM   #18
bajaracer1501's Avatar
I noticed the 3 different style Protek clutchbells on the Amain site were OFNA/Mugen, Kyosho & Losi. Based on that chart, is it safe to say an OFNA/Mugen style clutchbell will work with a Hot Bodies flywheel & shoes? Thanks
http://www.amainhobbies.com/index.ph...filter_mfr=209
bajaracer1501 is offline   Reply With Quote
Old 03-11-2009, 02:04 PM   #19
Integra's Avatar
monty
2nd pro buggy 4th pro truggy.
Old 03-11-2009, 04:07 PM   #20
houston's Avatar
awesome !!!! good job man .
wenatchee ?? spring shoot out ??
Old 03-11-2009, 04:32 PM   #21
pitpop's Avatar
I recommend using the same flywheel, clutch shoes and bell.... mixing & matching to create a hybrid clutch set-up is aking for trouble, there are some very minor differences in the stuff that can cause problems
Cody King's Wrench (and dad :))| Team Kyosho International | Reds Racing Engines | Pro-Line Tires
KO Propo | Byron Fuels | AbsoluteHobbyz.com | Stickit1 Racing | kustomrcgraphics.com
LiveRC.com | OCRC Raceway | codykingrc.com | ROAR Sanctioning Director
pitpop is offline   Reply With Quote
Old 03-11-2009, 04:44 PM   #22
houston's Avatar
Talking
yep , use all the items that come with one brands clutch setup
i prefer kyosho
Old 03-11-2009, 06:01 PM   #23
BIG RE's Avatar
Trader Rating: 32 (100%+)
I have been running Hot Bodies clutch bells on my kyoshos for a long time, no problem. You would want the kyosho style clutchbell for it
BIG RE is offline   Reply With Quote
Old 03-12-2009, 07:01 AM   #24
Krawl's Avatar
After a little googling, I have found that I run correct flywheel, it's OFNA...my clutchshoe also OFNA...but I haven't checked the flywheel post whether it's bent cause don't have the tools to remove the shoes....got to visit my LHS...I also found new suspect...it's the throttle/brake linkage...when I pull the throttle, the brake linkage went to the other side (yes, this is normal), but there's a little braking effect, and after I released the throttle, the braking effect still there...could be this is the main problem?
Krawl is offline   Reply With Quote
centax clutch ? HELP ! carpet_killa Nitro On-Road 60 10-13-2011 05:38 PM
