Old 06-11-2009, 10:48 AM   #46
Frank L's Avatar
Trader Rating: 148 (100%+)
The Losi RE-11 is an OEM copy of the OS 2050 just like the Mugen 2042 is an OEM copy of the OS 2060. I recently started running an OS speed and I like it so far. Last time I raced I used an Ofna 2053 with a long header in a 8T 2.0 it did ok, then I switched to the med header that comes with the Ofna pipe and it ran much better. The torque was good and the top speed was not bad running at 220-230. I was getting about 9.5 min on a tank and the engine was not quite fully broken in yet. I recently purchased a Mugen 2042 and JX L shaped header. I have been told this is the winning ticket with the OS engines. I am going to test it on Fri and see how it compares.
Another great upgrade is the EB mods head button it really brings the vspecs to life.
Old 06-11-2009, 12:37 PM   #47
+1 053 best bang for the buck
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 06-11-2009, 07:29 PM   #48
what about a 086?? Nobody is running that? would a jp3 be better suited, been running a dynamite 86. and dont' tell me jp3 cause i just bought another 086
I was told at my lhs that the 086 was the pipe for the vspec (they didn't have a 2060, besides to expensive)
dreaux is offline   Reply With Quote
Old 06-11-2009, 07:34 PM   #49
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Yep JP-3 would be a much better choice. The 086 is a top end pipe= not good for a v-spec. You want a low end or midrange pipe on the v-spec. IMO a top end pipe will completely kill the bottom end of a v-spec.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 06-11-2009, 08:05 PM   #50
Jaz240's Avatar
Trader Rating: 52 (100%+)
Ask your questions here and then go buy at your LHS..Dont ask them for advice anymore as they seem to be completely clueless, or the only pipe they had in stock to sell you was an 086..Go return it if you can..if not put in in your box..Its a great pipe to have to add to your arsenal, but not at all suited for the V-spec..086 pipe will be great with any engine that has 7 or more ports..which will greatly reduce your run times as well
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 06-11-2009, 09:31 PM   #51
Not sure about your 7 port theory, but you are definately correct about asking questions here. I have learned that most LHS's are completely useless when it comes to info.
Typically the more ports an engine has, the better the top end is. The fewer ports the better the low end. On high port engines you typically want to use a low end or midrange pipe. On low port engines(such as 3 ports) you usually want a top end pipe(086). The V-spec however is definately an exception to these rules. The v-spec has soo much top end as it is you really don't need a top end pipe. Personally I don't really focus on top end. As long as it is decent, I am fine with it. Now bottom to midrange is where you really need the power on most tracks. You can only really use the top end of most motors on very large tracks. Ok, so point is, usually a top end pipe such as the 086 is used on 3-5 port engines, not 7+ ports.
-Koby Kubrin-
Old 06-11-2009, 09:37 PM   #52
Jaz240's Avatar
Dont knock till you try! jammin JPX .21 is one of my favorite engines.. 7 ports..high end engine, 086 pipe is just killer all around, same for the Hyper .21 8 port..I understand your theory and it is correct, but experimentation on my part has allowed me to draw my own conclusions..next time you get a top end engine in your hands try the 086 on it..WOW MOMMA!!!
Old 06-12-2009, 02:35 AM   #53
RX313BT's Avatar
Trader Rating: 14 (100%+)
I have only ever run HongNor/gotech 2047 pipes on my V-Specs, smooth power delivery and ballistic top end.
Cheers
Adelaide RC Team Driver
WWW.ADELAIDERC.COM.AU
Xray XB9 & XT8.5, Proline, Nitro-X Fuel.
Xray XB4, Nosram, Proline.
TLR22,TLR22T Model Flight.
RX313BT is offline   Reply With Quote
Old 06-12-2009, 04:09 AM   #54
v1r killer's Avatar
i run a nova 9886 pipe with long header and get around the 9.30-10 min mark with it. it has good bottom to mid rang and screaming top end on a 6.5 carb insert. try it and and you will like it.
Bruce ( JUICEY ) Airey
Tekno EB48-3, RX8.2 1900, NB48-3, Nova P5
Coast2Coastrc, SMC batteries, FTW Bodies; Tekin; AKA Tyres
v1r killer is offline   Reply With Quote
Old 06-12-2009, 04:10 PM   #55
I am totally bummed now. I ordered the 86 from amain online. Is thier any way they will take it back?
Old 06-12-2009, 04:14 PM   #56
Jaz240's Avatar
Yes, just dont open the package..you will have to pay to ship it back, try the Losi RE-11 pipe. Thats what i use on the V-spec..awesome run times with a 7MM restrictor and smooth power from bottom to top
Old 06-12-2009, 04:20 PM   #57
It's been opened, it's actually on my car. Hasn't been run, but the package with the springs and gaskets has been opened. guess there is nothing that i can do except buy a new one.
Old 06-12-2009, 04:26 PM   #58
Jaz240's Avatar
Your not going to run V-specs for the rest of your life..086 is a great pipe to have
Old 06-12-2009, 04:28 PM   #59
going to order the re11. Thanx jazz. I am picking up my hitech 7955 servo tomorrow They are on back order everwhere on line and every hobby shop within 100 miles has it on back order. Except 1. and they have only one, and i found it. It's in new orleans, and i will be thier bright and early to pick it up.
Old 06-12-2009, 04:45 PM   #60
Originally Posted by Racecrafter View Post
Meilke/ EB Mods 2041 hands down the best pipe for the V-Spec or Speed.
+2 my speed is butter smooth with a 2041 ebmods pipe
rc-pro racing in gloucester va/TEAM TERRIBLES
ST-RR/8ight 2.0
osspeed,ebmods pipe,trinity platinum 30%,dx3r
crawldad91 is offline   Reply With Quote
**NSWRCRCC Inc. - Moorebank On-Road** VenomWorldOrder Australian Racing 11441 07-19-2017 03:19 AM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 07:17 AM
Temp guns - Basic questions noR Offroad Nitro Engine Forum 19 01-27-2013 07:25 PM
XRC 1/5 SCALE CARS brewer Australian Racing 3474 01-25-2011 03:10 AM
D&M Speedway Topeka Outdoor Off-Road JPMSRacing Kansas/Missouri Racing 5448 10-09-2010 09:01 AM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 07:19 AM
Best engine for <$400 C6BB7T v Plus 21-5KT v Werks TLB7pro magbarn Nitro Off-Road 47 07-06-2007 12:45 AM
