Old 03-10-2009, 09:00 AM   #1
joeduffy987's Avatar
Default Engine cuts off when i brake
The engine cuts off when i break even if just slightly any help any Pictures that can help would be greatly appreciated.
"Who are you to judge the life I live? I know I'm not perfect and I don't live to be, but before you start pointing fingers make sure your hands are clean". - Robert "Bob" Nesta Marley.
joeduffy987 is offline   Reply With Quote
Old 03-10-2009, 09:04 AM   #2
Charles Godwin's Avatar
Your idle screw is to far out. Turn it in more and it'll cure the problem
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 03-10-2009, 09:05 AM   #3
SkarTisu's Avatar
Send a message via AIM to SkarTisu Send a message via Yahoo to SkarTisu
It could be a few things:
- Idle is too low
- Low speed needle is too rich
- Clutch is hanging up
Marshall Skare
Team Associated - Reedy Powered - JConcepts - LiveRC.com
SkarTisu is offline   Reply With Quote
Old 03-10-2009, 09:12 AM   #4
Thanks guys =D
Old 03-10-2009, 03:28 PM   #5
RETRO RC's Avatar
If it's cutting out when you only just touch the brakes then it more than likely the clutch, check your bearings and springs
Adrian
Agama A8 EVO 11 spec/ Argus A52 .21
Agama A8T / Argus A52 .23
offroaders get more jumps and like it rougher!
RETRO RC is offline   Reply With Quote
Old 03-10-2009, 07:00 PM   #6
I have this problem but only after a long full throttle straight away, come to the end and brake and the motor dies. Thinking it is the clutch and had plans to change to the metal shoes. Hope it works
Giulitto is offline   Reply With Quote
Old 03-11-2009, 02:22 AM   #7
In your case I think it my be the tuning. To fat lsn, to high idle. Do a pinch test at 1/2 in. fuel inlet at carb. Should die around 3-4 sec. Talk to the old farts at the track.
The Working Man is offline   Reply With Quote
Old 03-11-2009, 04:26 PM   #8
pitpop's Avatar
did you get this resolved, is your rig running right now?
Cody King's Wrench (and dad :))| Team Kyosho International | Reds Racing Engines | Pro-Line Tires
KO Propo | Byron Fuels | AbsoluteHobbyz.com | Stickit1 Racing | kustomrcgraphics.com
LiveRC.com | OCRC Raceway | codykingrc.com | ROAR Sanctioning Director
pitpop is offline   Reply With Quote
Old 03-11-2009, 07:59 PM   #9
rced1's Avatar
Trader Rating: 17 (100%+)
Adrian
Also check the trim on the throttle servo. There should be a little space or slack before the servo horn starts moving the throttle arm. If the throttle arm moves in when you apply the brake then the trim and idle screw both needs to be adjusted.
Slow is fast.
rced1 is offline   Reply With Quote
"the tuning bible" houston Onroad Nitro Engine Zone 311 04-24-2017 11:18 PM
Batam RC Kopitiam batamrc Indonesia Racing 3502 07-28-2015 12:14 AM
Hong Nor / Jammin Products And RC Fans Thread plazma Malaysian R/C Racers 1717 04-02-2013 01:07 AM
Yay Dvx400Rider Nitro Off-Road 7 02-27-2009 08:25 PM
Engine Tuning 101 (General Tuning) Kemorc Onroad Nitro Engine Zone 41 11-19-2007 06:04 PM
