Old 03-08-2009, 04:33 PM   #1
pballer2777's Avatar
Trader Rating: 27 (100%+)
Default using digital and analog servos together
i was wondering can use use digital and analog servos together and set the frame rate on the radio for the faster speed. or will the faster frame rate effect the analog servo?
tlr 8 4.0 /rex engine/aka
tlr 8e 3.0/tekin/aka
pballer2777 is offline   Reply With Quote
Old 03-08-2009, 05:18 PM   #2
snookums's Avatar
On Futaba radios this will only work on PPM mode. HRS mode cannot be used with mixed analog and digital servos.
Currently Running:
Mugen MBX5r/OS .21VZB
Hobao HyperST/GO .28
Hobao Hyper7/GO 3port .21
snookums is offline   Reply With Quote
Old 03-08-2009, 05:26 PM   #3
Tree's Avatar
Send a message via ICQ to Tree
I hear the pros use an analog servo for throttle and a digital for steering. But most pros I have seen race still use FM radios. You can use both servos in the same car with a Nomadio radio.
Team Holy Rollers
HiTec Servos
"N-Tune" Nitro Engine Tuning Dials
Tree is offline   Reply With Quote
Old 03-08-2009, 05:49 PM   #4
i also want to use an analog for throtle and digital for steering. i have a dx3r. i do not have digital servos as of yet. but i also want to get the most out of them. so what i need to know is will setting the frame rate for digital steering servos affect the analog throtle servo.
Old 03-08-2009, 05:51 PM   #5
ace921000's Avatar
i have a dx2.0 and use analog for throttle and digital with steering and im fine.
ace921000 is offline   Reply With Quote
Old 03-08-2009, 05:53 PM   #6
Tree's Avatar
I am not too familiar with the DX3R. I know with my Nomadio, I can set each servo for either digital or analog.
Team Holy Rollers
HiTec Servos
Old 03-08-2009, 05:58 PM   #7
on the dx2.0 u can't set the frame rate. it is set to work with all servos. on the dx3r u can change the rate for the servo to react at different speeds. if i set the rate in the middle it will work. but with a digital servo u can use a fast rate. but i'm not sure if they will work together at the same higher rate
Old 03-08-2009, 06:47 PM   #8
Joey Powell's Avatar
It says right there on the radio that digital servos must be used for the 5.5ms frame rate. You may use any combo of digital and analog you like as long as you use the 11ms or 16.5ms frame rate. 11ms is still pretty quick.
Phin Design R/C (phindesignrc@gmail.com)---VP-Pro-USA---Maxy's Fuel & Engines---TKO Competition Development---
"There are no problems, only solutions."
Joey Powell is offline   Reply With Quote
Old 03-08-2009, 06:58 PM   #9
thats what i thought
Old 03-08-2009, 07:15 PM   #10
xxxrcnitro's Avatar
This is correct.You cannot mix digital and analog with Futaba Radios ppm or hrs only.
xxxrcnitro is offline   Reply With Quote
Old 03-08-2009, 07:36 PM   #11
GNS Racing 86's Avatar
im not sure what my radio is set on but i have a 3pm futaba
and i am using digital on the steering and analog on throttle.
i was told that digital on the throttle was not good to use.
but i have run it like this for 1 full season no problems
GNS RACING Got No Shame..... if it aint broke tweek it untill it is!!
TLR 8ight 3.0,- TLR 10 scte 2.0,- TLR 22sct,- TLR 22-4 TLR 22 2.0 TLR 8ight-t 3.0
GNS Racing 86 is offline   Reply With Quote
Old 03-08-2009, 07:57 PM   #12
it will work i run analog steering and digital throttle
tom slick 50 is offline   Reply With Quote
Old 03-08-2009, 08:50 PM   #13
jkas10's Avatar
Trader Rating: 121 (100%+)
You can mix analog and digital with Futaba FASST. You just have to set the radio to the lowest common denominator. So set the radio to PPM and you will be fine. If you can notice the difference of PPM vs. HRS on your digital servos, you must be one of the top racers in the world.
Digital servos work just fine on PPM, but analog will die very quickly on HRS Don't ask me how many analog servos it took me to figure that one out... IF your servo twitches uncontrollably and makes a terrible noise, that is bad
Jeremy Kasten - Cole's Pitman! (Dad); Kasten Racing: www.facebook.com/kastenracing
THANK YOU Sponsors: Mugen Seiki; REDS; AKA; Leadfinger Racing; NitroPro Fuel; RC Addiction Products; Dialed-RC Hobbies; Ben Brocato Designs (BDB); PT RC Racing Oils
jkas10 is offline   Reply With Quote
Old 03-08-2009, 09:56 PM   #14
markt311's Avatar
Trader Rating: 32 (100%+)
I use a dig for steering and analog for throttle with my dx3s with no problems, but you can't set the frame rate on dx3s.
PR Racing Bellgate Distributors
Caster Racing Parts
311 RC Graphics
markt311 is offline   Reply With Quote
Old 03-09-2009, 03:26 PM   #15
xxxrcnitro's Avatar
If your not in Hrs you cannot use fail safe its a pain to set fail safe manually every time and you will fry an anolog servo if you use Hrs.But way would you run a digital servo and not get the most out of it?
1/12 forum ovalnator Electric On-Road 45709 Today 05:19 AM
Xray NT1 aantonis Nitro On-Road 7512 08-14-2017 02:55 PM
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 05:09 AM
Glitches on Servo NOVICE4EVER Singapore R/C Racers 10 12-04-2007 08:24 AM
Newbies! Post Your Questions Here! AdR|aN Malaysian R/C Racers 610 12-07-2004 12:21 AM
