Old 03-08-2009, 06:45 AM   #16
Zerodefect's Avatar
Originally Posted by Giulitto View Post
I put loctite on my shaft end screw, this is the third time it has come loose. Where is the clutch nut screw? Once the clutch bell is removed everyting is just sitting there; bearings, washers and clutch shoes w/ springs.
Use only a small amout of thread lock, too much just makes it worse. Usually when my clutch screw loosens, if it loosens, its time to clean the clutch anyway.
I like to let the threadlock dry overnight.
If your engine or clutch gets too hot it'll loosen up the thread lock.
If your clutch bearings are shot it could shake things loose.
If your clutch gear is hitting the chassis that'll knock things loose to.
If your clutch endplay is set too tight that can cause the clutch screw to have a load on it that'll eventually loosen it as well.
If a sparrow flys over the track on a cloudy day that'll loosen the clutch screw.
If your car has the color blue on it anywhere........yup, loose clutch screw!
The clutch nut is under the clutch shoes. Its holding on the flywheel. The screw that threads into the crank and holds the clutch bell on, I call it the clutch screw or crank screw.
Zerodefect is offline   Reply With Quote
Old 03-08-2009, 07:11 AM   #17
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
Originally Posted by GregH View Post
Dude, take some short typing classes while your at it.
I guess your not used to PorkChop's typing! Gots to use the PorkChopanese translator
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Grande Prairie Model Racers Association WheelNut Canadian R/C Scene 19805 06-10-2017 01:40 PM
SAVAGE - SS, .25, .21 Official Thread! Horatio Monster Trucks 11167 05-15-2017 08:40 PM
CASTER RACING MALAYSIA Radical Freaks Malaysian R/C Racers 321 07-15-2014 07:55 AM
GRP... Engine... Thread... xlgraphicspro Offroad Nitro Engine Forum 2135 09-10-2013 08:46 AM
Crazy OS V-Spec Break In Methods? Don Duct Nitro Off-Road 22 05-12-2008 06:17 AM
FOCAR RACE #3 FAST TRACK HOBBIES! UCHEATULOSE Florida Racing 35 06-12-2006 05:02 PM
Texas Biggie TexasRacer Nitro On-Road 74 06-03-2005 10:10 PM
