Old 03-06-2009, 06:44 PM   #1
Default New to nitro
Guys,
I need help. I just got a new Losi 8ight 2.0. Im new at nitro so bare with me.
The engine i selected was the novarossi p5xst. My first question is this:
When i go to install this, the mount that connects the throttle servo to the engine is on the opposite side from what i see in the pics. It is closest to the pipe.
That does not seem right? Is there a way to switch that??? Im lost there.
Also, what pipe do you guys suggest i use with this motor?
Lastly, when i have the motor out and holding in my hand and i try and rotate the crankshaft, it does not go all the way around. Now i assume this is due to the compression build up but tell me im right before I bust something!
Again, thanks in advance for any responses.
thanks!
moto27 is offline   Reply With Quote
Old 03-06-2009, 06:51 PM   #2
BAUSTIN's Avatar
there is a screw in the motor case at the base of the carb, carfully loosen it and flip the carb 180 deg....here is ur engine it is the flat head screw you see....loosen it and you can move the carb to where u need it it could still be tight after you loosen the screw but it has to be turned around....
http://www.farmamodellismo.it/catalo...x-21p5xs_2.jpg
also you want to turn the carb to the point the linkage is pulling in as clos to straight line as possible, the carb wont be square to the motor it will be turrned a few deg im shure.....
the piston sleve are made to get tighter as the piston reaches the top of the stroke, so when the engine is up to temp the fit is perfect......the first couple times you run it or some ppl do it all the time is heat up the motor with a heat gun or hair dryer before you try to start it.
sorry ive never ran this motor so i cant help on the pipe......
Billy Austin
www.Code3RC.com
Elevation Sports
BAUSTIN is offline   Reply With Quote
Old 03-06-2009, 07:35 PM   #3
Thank you for that. Also, that red thing in the top of the carb, does that stay in?
Old 03-06-2009, 08:01 PM   #4
rearviewmirror's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rearviewmirror Send a message via Yahoo to rearviewmirror
That is a carb venturi, it's a tuning tool. You can limit the air flow into the engine so you can actually decrease some power and get long run time. You'll see that on really loose tracks where people don't want to lay down all the power. If you're new run the smallest venturi you can get for that engine, less power and longer run time is good if you're learning.
ARCTIC DOG RACING (Nitro free since 2009)
"Straights are for fast cars, curves are for fast drivers...."
8ight-E / 8ight-TE / T4 / Slash
rearviewmirror is offline   Reply With Quote
Old 03-06-2009, 09:00 PM   #5
I just ordered the same engine except this ones modded by hot mods and has ceramic bearings. Cant wait to get it and run it. I was told the jp3, Novarossi 9886 = ofna 086 ( i guess there the same pipe) but rated #1 pipes for this engine. I am gunna run a 053 and axe rossi 2050. I will have to see which 1 i like better at the track. I have to wait another month before the weather lets me run it so when you get your let me know how it runs!!!
r1nsho is offline   Reply With Quote
Old 03-08-2009, 05:48 PM   #6
Yea...I went with the jp3. Its solid for what I saw at the track. Most that had this engine were running that. Good luck!
Old 03-08-2009, 05:59 PM   #7
littlelane's Avatar
the nova 9901 or dynamite platinum 053 for small tracks and the086 for larger ones i have 2 of these 1 p5xst stock on a losi 8 1.0 and its awesome the other is a modded p5xst from pro twister that is truly amazing i run the 9901 on truggy and the 053 on buggy
littlelane is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17215 08-16-2017 11:12 PM
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 10:20 PM
Nitro On-Road Addict sa RC Manila Racers 12522 12-27-2015 05:51 PM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 07:19 AM
XB8 EC & lots of parts nitro rat Australia For Sale/Trade 6 09-23-2008 02:43 AM
IMPORTANT info About North Ga Summer Nitro Series bigde2001 Georgia Racing 45 09-14-2008 01:03 PM
NEW IN DOOR RC TRACK!! * Red Frog RC * Off-road 403forbidden Northwest Racers 1149 07-24-2006 11:16 PM
