Old 03-07-2009, 06:31 AM   #31
Integra's Avatar
Originally Posted by ezveedub View Post
Maybe on truggy, but buggy has been fine so far.
1g needed even for the Grid Iron's.....NO tire is 100% perfect.....its just the way things go unfortunately.
Old 03-07-2009, 06:39 AM   #32
Trader Rating: 163 (100%+)
its better then the half pound you have to put on a proline tire to get it to balance out
cjm1126 is offline   Reply With Quote
Old 03-07-2009, 06:45 AM   #33
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
+1, those vibrate and need balancing.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 03-07-2009, 07:09 AM   #34
Integra's Avatar
ok look...do i need to take a vid of the couple truggy Citi and Ibeam PRE mount soft's that developed a wobble 2 quali's in...and REquired 3+grams to balance out....im not trying to pull your leg here.....you want pics of the wheels with weight sitting at all different position's on the balancer ? what would you like ?
Old 03-07-2009, 07:18 AM   #35
ezveedub's Avatar
OK, if they were fine new and they got out of balance after TWO qualifiers, the rims are most likely bent or dinged. The AKA foams haven't distorted after use from what I have seen. Out of the box, they are generally fine. If we had wheels that were OK new and vibrated bad after a few runs, they are tossed away, simple as that. Also, I don't use PRE mounts. The PRE mounts generally come loose and are out of balance. Thats has been a ProLine issue, bottom line. Go take a look at some and see for yourself.
Old 03-07-2009, 07:22 AM   #36
the jconcept truggy crosshairs i have been running dont need any balancing, there isnt a bit of wobble
Old 03-07-2009, 07:34 AM   #37
Integra's Avatar
who said anything about proline......these are buddy's Premount's were talkin....My glue job citi's beams and Grid's ALL needed about the same amount of weight also....all the buggy citi's beams and grid's took anywhere from .6g to 1.6g to get perfect.....the truggy's on the other hand were more like 2.6g+....1 extreme came out at 6gr to get purfect and it was a I-Beam...the tire's i balanced at the track last weekend took around 4-4.5g to get perfect which were Pre mount citi-beam Soft truggy combo...out of the package I ran one quali and balanced after Noticing an Wobble the SECOND i started it on the box.....Revving it wobble'd a little but on the rev down the 1 tire shook like it was out..that tire took 5grams if i remember correctly....iM ANAL on my tire's if you cant tell already.
Old 03-07-2009, 11:14 PM   #38
Proline truggy foam can be far out of balance. And it moves around inside the tire as you drive . So your once balanced tires wont say that way. J Concepts foam is much better. It seams that the truggy holeshots are the only proline tire I can wear out without the foams causing balance problems.
Proline buggy foam since there is less of it has less balance problems. I have had the proline buggy foam breakdown and get lumps in the tire. The J Concepts foam appears to suffer less breakdown.
The quality of the tires are good from both companys. The J Concepts tires do not have as much molding flash on the mounting lip so are less work to mount up.
I think that proline will have new foams and flat profile truggy tires soon to compete with J Concepts. I wear out only 2 or 3 sets a month and I can see whats up. So I am shure proline knows whats up.
luckyhomes is offline   Reply With Quote
Old 03-08-2009, 09:24 AM   #39
We are looking to buy jconcepts in to the uk . Iff the insert are moving when driving mayby glue them on the rims than the wheel will be never be out of balance .
cube1984 is offline   Reply With Quote
Old 03-08-2009, 06:12 PM   #40
It may work but what glue would you use? shoe goo maybe? What ever you use would have to test on a small section to see if it attacks the foam. Also I think the surface of the foam that is glued may rip away from the rest of the foam. Plus its just 1 more step in a job that sucks anyway. It may handle better or balloon less but I am too poor to risk killing a set of tires. I am just gona buy the J concepts stuff. I did see on the internet somebody saying to wrap the foam with packing tape. I never tried it for the same reason I said above.
Old 03-08-2009, 06:36 PM   #41
Joey Powell's Avatar
JConcepts...Ruona's got it goin' on!
Phin Design R/C (phindesignrc@gmail.com)---VP-Pro-USA---Maxy's Fuel & Engines---TKO Competition Development---
"There are no problems, only solutions."
Joey Powell is offline   Reply With Quote
Old 03-09-2009, 02:13 AM   #42
still lookig in to the eu if they got the new jconcepts
Old 03-09-2009, 04:19 AM   #43
What is the effect of the large rims on a buggy?
Old 03-09-2009, 06:25 AM   #44
AndyMoore's Avatar
Trader Rating: 53 (100%+)
Send a message via AIM to AndyMoore
LRP is our distributor for most of mainland Europe and SMD is our exclusive in the UK.
http://www.s-m-d.co.uk/
|JConcepts|Winning Edge Designs|
AndyMoore is offline   Reply With Quote
Old 03-10-2009, 02:43 AM   #45
hello andy,
Thx for the info i will contact lrp or smd thx
Mugen MBX6 teeforb Nitro Off-Road 18539 03-20-2016 02:59 PM
Thank You Woody Garwood bcrazy Northwest Racers 22 03-20-2010 10:24 AM
High Desert Raceplace GJ CO bcrazy Colorado Racing 235 12-21-2009 02:21 PM
Western Slope Challenge @ High Desert Raceplace GJ CO bcrazy Electric Off-Road 9 04-27-2009 02:23 PM
Western Slope Challenge @ High Desert Raceplace GJ CO bcrazy Racing Forum 7 04-26-2009 04:04 PM
