Old 04-14-2009, 09:59 PM   #76
Mr. Twister's Avatar
Originally Posted by strngdze View Post
I got this on road manifold from A-main to use with my 2053 on the bench.
http://www.amainhobbies.com/product_...ducts_id/13559
ok cool, i use the RB short header, that header you have will do the trick.
Brian Carey
615-838-5373
Tennessee Oval Performance
Check us out on Facebook
Mr. Twister is offline   Reply With Quote
Old 04-14-2009, 10:26 PM   #77
dhopkins8's Avatar
Default strngdze
Dave,
Don't get any crazy ideas of using that flywheel puller on that sweet mill.
HA HA
Dan
dhopkins8 is offline   Reply With Quote
Old 04-14-2009, 10:55 PM   #78
Nitro$junkie's Avatar
Send a message via MSN to Nitro$junkie
Originally Posted by Mr. Twister View Post
the stock Toro isn't a lightswitch on bottom, I always felt like it had a spool up of the plus 4 but a little stronger, and mid and top it starts getting hairy, i guess i would say the JP4 may be the best bet, that way you have a consistant feel low or high grip.
1+ i found the same also i have a Toro running 25% with MSR1005 pipe and found its got a nice smooth bottem and a wild mid and top end she was also a dream to run in just as easy as my speed but i run lipo in my starter and she did still lock a few times
Futaba
Mugen
Novarossi
Byron's
http://www.hospitalrecords.com
Nitro$junkie is offline   Reply With Quote
Old 04-15-2009, 03:10 PM   #79
I haven't seen a Toro Nero in action, it should have a ton of torque with that bore to stroke relation, and since off road does not need to much rpm the downsides are probably nil, but I really can't imagine any engine right now to be as powerful anywhere in the rpm range as an FMS, its simply the fastest motor on the track, and by far, incredibly it's still smooth, the thing just follows your throttle finger like a train on a railway - absolutely no lag.
maxflo777 is offline   Reply With Quote
Old 04-15-2009, 03:48 PM   #80
Frank L's Avatar
Trader Rating: 148 (100%+)
Where do I get one of these FMS engines and how much are they??
Old 04-15-2009, 05:38 PM   #81
http://protwistermods.com/index.php?...mart&Itemid=53
Brian Carey
615-838-5373
Old 04-16-2009, 10:23 AM   #82
vince7870's Avatar
Trader Rating: 15 (100%+)
Anyone know if the toro has a new special plug or not? Looks a little different than the standard nova turbo plug. Also what number are you toro guys using?
Lead, Follow or get out of my way!
vince7870 is offline   Reply With Quote
Old 04-16-2009, 10:49 AM   #83
nothing new about the plug that comes with it, we are running the 6TGC
Brian Carey
615-838-5373
Old 04-19-2009, 12:52 PM   #84
Put my Toro in a D8. Running an 053, thanks to the advice of Houston. Lots of power, and very controllable.
Miniracer23 is offline   Reply With Quote
Old 04-20-2009, 09:40 AM   #85
jds5150's Avatar
Default header and exhaust for buggy and truggy
I have a NR plus 4 for my D8 and NR Toro Nero for my D8T. What's the best NR pipe header combo for the buggy and truggy.
jds5150 is offline   Reply With Quote
Old 01-21-2010, 12:26 PM   #86
3rici985's Avatar
Originally Posted by rceefreak View Post
I have both the toro nero and the fms. Waiting for the 9901 pipes to be in stock somewhere. I'm starting to get tired of waiting. What is the 2nd pipe choice-053 or jp3?
What do you prefer the FMS or Toro, and more importantly Why do like 1 more than the other.
Eric Seifert
MUGEN MBX6T
SIXNINETEENRC.com
3rici985 is offline   Reply With Quote
Which one Rb B9 Or nova rossi +4 Quietman Nitro Off-Road 17 07-05-2010 05:30 PM
