which truggy motor????????
not sure what motor to go with for truggy. I know I want a .28 but everyone says the OS is too much power. What do you recommend and why?
GO TECH .25 6 port race. Just as powerful down low as a .28 with rpm's and runtime similar to the .21's. THE BEST OF BOTH WORLDS. No need for a .28, but if your heart is set on 1 GO tech makes a few but the .25 is a monster. Truly unbelivable power...
honestly you would be better off with a strong .21 like the ebm5 race prepped , it will have more then enough power to clear jumps but at the same time not have to much power to where you are spinning the tires out of every corner costing time
Yes I agree but he said .28. I smashed .28's in truggy last year with my PTM Go Tech .21 5 port. If you go with the EB get the race prepped model I talked to ED and he said it is more suited to truggy. The full mod is for buggy because his modding smoothes out the abrupt bottum of the 5 port.
JX .21 hands down:nod: awesome drivable bottom end power, use a JP3 or 2060 and you have a lethal combination, this set up van be ran on small indoor tracks or bid fast flowing track's, it has OS tuning and reliablilty, and 5 ports and ceramic coated crank, runtimes with the mentioned pipes are 10 min plus, the motor is just wicked fast when you want it to be, and smooth when you want it.
whats wrong wiht a plain ole vspec!
extech .24 fullmod 299.00 :nod:
My next truggy engine JX.21 |
guys the st-rr has 150cc fuel tank..didnt they make that so that you can have the runtime of a 21 and the power of the 28?
Originally Posted by didrace
(Post 5515622)
My os .28 is thirsty like hell. |
i used os speed 21 on my losi 8t no problem on the handling side, and it can run with the 28 guys and less fuel consumption.
(Post 5515622)
Personally I had a .21 Rossi in my truggy and I was blowing the .28's out of the water
Not only with speed in tight corners [slow is fast], and a little better fuel mileage but if you get a .28 go with a RB5 port but if you get a .21 get a .21 GRP promo kit <-- runs amazing |
Originally Posted by Mlbracing
(Post 5515850)
Extech .24 or .21, either have ton's of power especially the .24 but you'll actually get decent run time out of them.
Originally Posted by Qmartin
(Post 5516319)
