Old 03-04-2009, 07:24 AM   #1
Default xt8 big bore
hi guys, need some advice, i am using caster racing big bore suspension and it seems the front suspension seem to be touching the front drive axles.
do u have any solutions??
muaythai is offline   Reply With Quote
Old 03-04-2009, 09:14 AM   #2
slaytanic's Avatar
Trader Rating: 20 (95%+)
Can you space out you shock standoffs? Did you use the caster ones? I would think the xt8 stockers would be the cuase as they are designed for the 14mm shocks.
Team Epic
Team Terribles~Answer RC~Fastlane Graphics~Torco Race Fuels
XB808 Mamba Max Pro/Tekin 1900kv RC-monster mount and tray 4s
XT8 Hobbywing 150a esc/2000kv combo KILLER! Full rc-monster e conversion. 4s
slaytanic is offline   Reply With Quote
Old 03-04-2009, 01:49 PM   #3
Default xt8
yeah i am using caster ones. the rear fit well. but the front seem to be too close. what do u mean by space out the shock standoffs
Old 03-04-2009, 02:45 PM   #4
Jackie_W's Avatar
Trader Rating: 16 (100%+)
You can space the front arms back to get more room but they will still hit the axles.As long as it's not causing any drag run it.I've run the ofna BB's and the 808 BB's and they all touch the axle.
Jackie_W is offline   Reply With Quote
Old 03-04-2009, 05:00 PM   #5
wild gopher's Avatar
Trader Rating: 39 (100%+)
get the Xray big bores when they come out. The front XT8's are the same as the rear 808's, the new rear XT8's are all new and much longer
RCtech - Filling me with adult drama since 2003
wild gopher is offline   Reply With Quote
Old 03-04-2009, 05:17 PM   #6
Jackie_W's Avatar
The front's will still rub unless they changed the new truck arms to move the bottom of the shocks out or make the driveshafts thinner.I ran the 808 rears all around at the Psycho Nitro Blast and they rubbed and never had a problem.
Old 03-04-2009, 05:30 PM   #7
Jackie_W's Avatar
Xray XT8 2009 spec
Here's pics of Josh Wheelers truck at the Nitro Challenge.
Old 03-05-2009, 01:32 AM   #8
Default xt8
Originally Posted by Jackie_W View Post
Xray XT8 2009 spec
thanks jackie i actually just asked the link above about the front axles rubbing the shocks.....
i suppose as long they not grinding either of them it will be fine. i just think they will wear faster
Coffee Shop for 1/8 RC Offroad mikeychenchiulu Indonesia Racing 10180 11-29-2013 03:39 PM
Hong Nor / Jammin Products And RC Fans Thread plazma Malaysian R/C Racers 1717 04-02-2013 01:07 AM
