Old 03-03-2009, 08:13 PM   #1
Questions?? Engine troubles
Today when I tried to start my engine It wouldnt go. The one thing I noticed is that it doesnt make the pop pop pop sound or spin the flywheel when I turnover the engine with my roto starter. But when I take the glowplug out and then turn over the engine it does go pop pop pop and spins the flywheel. Is this the reason that its not starting? If so how do I fix it.
Cheers
Silencedsteak is offline   Reply With Quote
Old 03-03-2009, 08:25 PM   #2
Trey7's Avatar
Your one way bearing is slipping. Replace it and you will be good to go.
Trey7 is offline   Reply With Quote
Old 03-03-2009, 09:36 PM   #3
BIG RE's Avatar
Trader Rating: 32 (100%+)
a lot of times, you can just clean the one way, and it will be fine for a little while
BIG RE is offline   Reply With Quote
Old 03-03-2009, 09:40 PM   #4
I am new to this hobby. Where do I find the one way bearing?
Old 03-03-2009, 10:36 PM   #5
Where you stick your rotostart rod, there should be 4 screws holding on that backing plate. Take those out and you should unveil the one way bearing. It is right behind where your starter shaft goes in.
Clay Grantham
TLR 8ight 3.0/Futaba 4PLS/WERKS B5 .21/VP Fuels
motoclay is offline   Reply With Quote
Old 03-04-2009, 01:39 AM   #6
shanty140's Avatar
Yup sounds like a One wear bearing. Usually when its first starts slipping you can get away with just cleaning it with some nitro cleaner spray and putting it back in and you good to go. If it's actually missing some rollers then you will need a new one.
Do you mind me asking what vehicle you have so I can help you out more. If I knew I could get you the part number of the one way bearing if you actually need a new one. Or how to get at the one way bearing on your motor. On most cases you just take off the backplate for the rotostart on the motor. Should be about 4 screws or so.
Race Vehicles:
Mugen MBX6T - Ninja JX.21 with EB Mods Headbutton, O.S. 2060 Pipe, DX3R, Hitec 7955TG Servos on LiPo
HPI Cup Racer - Murfdogg Synergy 17.5, Tekin RS Pro, 2S 40C 4200mah, DX3R, Sav÷x SC-1251MG Servo
shanty140 is offline   Reply With Quote
Old 03-04-2009, 07:25 PM   #7
I dont know whether you've heard of it but I have a HSP savagery and its a 1/8 scale. I think you just take the four skrews out to get to it like you said. I will try cleaning it. Below is a pic of my car.
OS FS26S-C 4-stroke development mxwrench Offroad Nitro Engine Forum 1639 Today 12:36 AM
More engine troubles... Help please! LordAnubis Nitro Off-Road 15 08-02-2009 03:34 AM
engine troubles rcbc Nitro Off-Road 8 05-15-2008 01:52 PM
IV Latin American Cup Race in Puerto Rico sneezer714 Nitro On-Road 212 07-19-2007 12:34 PM
nitro newbie need advice downunder23 Electric Off-Road 121 02-26-2006 03:35 PM
