Old 03-03-2009, 01:34 PM   #1
TRIPC's Avatar
Default How do I get the most steering out of a Losi 8 Buggy??
What are some ways to get the most out of the Losi 8 buggy? I have read that the steering is not best on the 1st gen and was improved on the 2.0. What will help the 1.0 steering??
Losi 8B OS V-Spec/Ex-Tech/Novarossi
Losi 8T OS V-Spec (in the works)!
Spektrum DX3S
TRIPC is offline   Reply With Quote
Old 03-03-2009, 02:08 PM   #2
news1213's Avatar
Turn your dual rate all the way up..
Nah, really, the Losi's don't have any (lack of) steering that I know of, if anything, it has too much for some people.
If you want aggressive and lots of steering, go with 5-7-2 in the diffs and put about 2deg of toe-out in the front.
Also make sure you have the right tires for your track.
Chris
news1213 is offline   Reply With Quote
Old 03-03-2009, 03:36 PM   #3
you can install the front aluminum knuckles to get more steering. They might have changed the geometry on the 2.0 knuckles to that of the aluminum ones and you could get those to save a lil $$ but I dunno if thier the same.
car:losi 8ight
engine:werks B3, Novarossi P5XS
radio:DX3R,Ace DS1313
vroom88 is offline   Reply With Quote
Old 03-03-2009, 04:55 PM   #4
If off-power steering is what your looking for, aren't the smart diffs made for that?
Yes, they cost $90, but if they work.....
I've never had an issue with lack of steering with the 5-7-2 diff oils.
groundhogg is offline   Reply With Quote
Old 03-03-2009, 05:01 PM   #5
TRIPC's Avatar
On your steering throw or EPA do you set it to steer all the way so it smacks the steering stops or do you set it to steer about 95-99% of the way? More toe out will give me more steering right??
Spektrum DX3S
Old 03-03-2009, 05:13 PM   #6
If you want more steering out of the 8ight the easiest thing to do is use the shorter ackerman plate.
Losi-Runner is offline   Reply With Quote
Old 03-04-2009, 07:49 AM   #7
TRIPC's Avatar
Does the longer ackerman plate come on the RTR??
Spektrum DX3S
Old 03-04-2009, 11:28 AM   #8
BOOST's Avatar
Long ackerman comes with the buggy and the short one comes with the truggy. Both come with the rollers.
BOOST is offline   Reply With Quote
Old 03-04-2009, 11:45 AM   #9
cdbias's Avatar
You can try:
Short Ackerman---Will make the car very "twitchy" all around the track though.
Center Smart Diff----Takes some getting used to.
Toe Out- Not so much that it hurts your straight speed
Rear Hubs-- Put some spacers behind the hubs instead of in front. It will help the car rotate more freely. I usually only do this on tight/technical tracks.
Hope this helps.
Thank You,
Casey Bias
Tekno RC | Jconcepts| Trinity | Hobbywing | MKS Servos | Elevation Sports | Code 3 RC |
cdbias is offline   Reply With Quote
Old 03-04-2009, 12:01 PM   #10
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Well... the shorter ackerman makes the steering more aggressive, as noted. You could try lighter front diff fluid... or for that matter, lighter rear fluid. Smaller front swaybar, or stiffer rear bar. Make sure you set the car up as indicated in the manual- unlike most buggies, it likes about 2mm more ride height in the rear. I don't remember if the Losi has a front roll-center adjustment, but if it does, raising the roll center (moving the inside end of the upper control arm up on the shock tower) will make the steering more aggressive.
Try those changes ONE AT A TIME and note the results.
And I have to say, this is the first time I've heard that the Losi didn't have enough steering. I had one, and it was a handful! Some of the other buggies may have "caught up to it" now, but a year ago there was nothing that could turn with it... nothing!
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Academy's new 1/10 scale buggy SBV2 PRO rcforum Electric Off-Road 2964 12-10-2011 11:16 AM
1/8th Buggy Shoot out Nitro$junkie Electric Off-Road 39 05-25-2007 04:09 PM
Lost 8ight/8T vs Mugen MBX5R/MBX5T brent98rt Electric Off-Road 32 05-20-2007 08:59 PM
Losi 8ight Pics Doug D Electric Off-Road 778 01-30-2007 02:41 PM
Considering some OFNA/CEN Buggies TxCZShooter Electric Off-Road 28 01-17-2007 07:01 AM
