Old 03-03-2009, 11:46 AM   #16
cdbias's Avatar
The "race roller" setup that comes on the car is very good and user friendly until you become adjusted to the car. After the car is broken in and you feel comfortable I would suggest using Mike Truhe's setup and go from there. Hope this helps and hope you enjoy the car!
Thank You,
Casey Bias
Tekno RC | Jconcepts| Trinity | Hobbywing | MKS Servos | Elevation Sports | Code 3 RC |
cdbias is offline   Reply With Quote
Old 03-03-2009, 11:52 AM   #17
RacerScott's Avatar
Thanks for the comment, but I meant what is the most reliable servo saver setup to go with, sorry about the confusion.
VP powermaster fuel | Upgrade RC
Scott U.
RacerScott is offline   Reply With Quote
Old 03-03-2009, 12:28 PM   #18
The 2.0 spring is not only thicker wire but also has more coils closer together. I think most of the problem is the spring is coil binding and has no give. The best answer seems to be to run the 1.0 truggy spring (LOSA4407) on the buggy and truggy.
gasser is offline   Reply With Quote
Old 03-03-2009, 02:08 PM   #19
Gergely's Avatar
Alu servo saver and servo arms with looser preload than factory setting.
Gergely is offline   Reply With Quote
Old 03-03-2009, 03:51 PM   #20
BOOST's Avatar
I personally think that there is nothing wrong with the plastic, but instead the spring is too strong. I compared my 2.0B spring with the 1.0T spring and it is slightly thicker and has an extra coil. The spring is way too stiff...So since I didn't have a 2.0 ally arm I used my 1.0 arm and plastic with the 1.0T spring and used the other other new bits to complete the servo saver. I can now race without worrying about the damn thing busting on me.
BOOST is offline   Reply With Quote
Old 03-03-2009, 07:20 PM   #21
Are the 1.0 truggy spring stronger than the 1.0 buggy. Why they tell us to use the 1.0T in the 1.0 Buggy too?
triloya is offline   Reply With Quote
Old 03-03-2009, 07:55 PM   #22
The 1.0 buggy spring was on the weak side and if you tightened it up to the point that it should have worked it would coil bind and the saver wouldn't function. The 1.0 truggy spring is stiffer and works great in the buggy and truggy.
Old 03-03-2009, 09:25 PM   #23
Ok...anyone try this Fioroni 8ight spring?
http://www.amainhobbies.com/product_...ducts_id/13244
Old 03-03-2009, 09:33 PM   #24
Integra's Avatar
too stiff imo...go with the 1.0T version.
Old 03-10-2009, 07:07 PM   #25
RacerScott's Avatar
Is this all I need to convert to the 1.0t spring on the 2.0 buggy?
http://www.amainhobbies.com/product_...ducts_id/12278
Scott U.
Old 03-10-2009, 07:22 PM   #26
Integra's Avatar
you might want to pick up the alum 2.0 top as well.
8IGHT 2.0! BAUSTIN Nitro Off-Road 14679 09-12-2015 07:58 AM
