Old 03-02-2009, 04:41 PM   #1
gravediggermaxx's Avatar
Trader Rating: 69 (100%+)
Default losi 8ight starter box question
im not sure if this is in the right section or not but i am having alot of trouble out of the motors im my 8ight starter box . does anyone know of a different motor to put in it?
gravediggermaxx is offline   Reply With Quote
Old 03-02-2009, 05:19 PM   #2
put traxxas E-Maxx motors in it, wire it with heavier wire, and deans plugs on your battery connectors.
Clay Grantham
TLR 8ight 3.0/Futaba 4PLS/WERKS B5 .21/VP Fuels
motoclay is offline   Reply With Quote
Old 03-02-2009, 05:58 PM   #3
what pinions do you use?
Old 03-02-2009, 06:33 PM   #4
now that, i do not know. I run the ofna truggy box, but have seen the latter set up and it seems to work well. but i do not know the pinions used, someone will chime in here, i read about it once on here to begin with.
Clay Grantham
Old 03-02-2009, 06:59 PM   #5
losi_racer's Avatar
Trader Rating: 25 (100%+)
gravedigger ill help u, i just went thru this....
i use integy 65t motors and have had no issues with it but some people have said i should of done 45t, once you get 2 motors you like grab the STOCK losi pulleys, if you grab any others the belt will walk all over the pinions because they dont have a guide for the belt. then get bigger gauge wire, 12g will be fine, i used novak wire but wet noodle works good too, also while your at it get new connectors for your battery i use deans with my lipo. here are links to the motors i used and the pulleys
http://www.amainhobbies.com/product_...ducts_id/16166
http://www.amainhobbies.com/product_...ducts_id/20266
http://www.amainhobbies.com/product_...ducts_id/10558
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
The Nitro Pit Dbackmasta Arizona-New Mexico Racing 18732 09-13-2012 08:27 AM
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 08:43 AM
Losi Truggy rcfreak24 Nitro Off-Road 1884 12-27-2009 12:53 PM
8ight-t RTR bump start conversion desertbird Nitro Off-Road 7 04-10-2008 02:36 PM
Losi 8ight T RTR reddishdsb Nitro Off-Road 117 03-08-2008 07:48 PM
Losi 8ight-T Race Roller engine type paco62 Nitro Off-Road 22 03-03-2008 07:47 PM
