Old 03-03-2009, 08:55 PM   #16
Steebo's Avatar
Trader Rating: 17 (100%+)
I had one batch of logo wear made up and they went like hot cakes! I plan on having more stuff made up when we get a little closer to the outdoor season.
Its awesome to see all of the great feedback from everyone!
Team Associated, Factory Team, Reedy, LRP, Impulse r/c, Upgrade r/c
www.impulse-rc.com
Steebo is offline   Reply With Quote
Old 03-04-2009, 05:34 AM   #17
sp2thielen's Avatar
Send a message via MSN to sp2thielen
man you gave away my shirt! lol i stikk want one steebo
IMPULSE RC when only the very best will do!!!!
Hobbytown Hobbyplex
Kyosho SP2/ Medial Pro
Kyosho ST-RR/ Medial Pro
sp2thielen is offline   Reply With Quote
Old 03-04-2009, 06:42 AM   #18
mfrosty's Avatar
Trader Rating: 14 (89%+)
Originally Posted by mfrosty View Post
Can I use these with a MBX5 clutch?
Anyone care to answer me????
mfrosty is offline   Reply With Quote
Old 03-04-2009, 06:59 AM   #19
i'm sure you can if you check to see how thick and long the pin is i can check mine later and let you know but i'm pretty sure
Garrison is offline   Reply With Quote
Old 03-04-2009, 07:09 AM   #20
mfrosty's Avatar
I'll have to break out my calipers and check when I get home from work
Old 03-04-2009, 03:55 PM   #21
Steebo's Avatar
There is a Mugen Driver in TX that I know of that uses the Mugen Flywheel with the Impulse-r/c shoes. Double check the Dia. of the pins on your flywheel, they need to be 2.5mm or .098 in. Just pick up an AE clutch nut and springs and you will be all set.
The best part about Impulse-r/c shoes is that you can keep your clutch fresh all the time without breaking the bank. All of this awesome feed back makes me want to build the standard style as well....hmmm!
www.impulse-rc.com
Old 03-04-2009, 06:26 PM   #22
Trader Rating: 85 (99%+)
I think it would be worth your while!!!
WideOpenThrottle RC is offline   Reply With Quote
Old 03-08-2009, 07:48 PM   #23
Steebo's Avatar
Standard style shoes will be available on the site on March 16th in the 2024 version.
www.impulse-rc.com
Old 03-09-2009, 07:51 PM   #24
That's gonna give alot of people a great option to the $20 a set shoes.....
Old 03-09-2009, 11:58 PM   #25
Matt Howard's Avatar
I tried the impulse-rc clutch shoes on my 8ight-E and instantly grew 2 inches, lost 20 lbs and dropped my laptimes by 3 seconds HI STEEEEEEBY
(the above is a joke, I didn't really lose 20 lbs)
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 03-10-2009, 10:45 AM   #26
Steebo's Avatar
HAHAHA!!! LOL! Thats Awesome! Whats crazy is that I think I've gained 20lbs since I started building them. How is the weather down there? It is snowing here today.....Man I LOVE Nebraska!!!!!
www.impulse-rc.com
Old 03-16-2009, 05:35 PM   #27
Trader Rating: 14 (100%+)
Originally Posted by Fugate View Post
I have been running these on my D8 by just using the RC8 clutch nut and springs. You'll have to shim the collet a little if you use the HB flywheel. I started off with 3 - 1.0 springs but will probably test some .9s.
After a little testing....I think the 1.0s are the way to go.
Fugate is offline   Reply With Quote
Old 03-16-2009, 05:41 PM   #28
Steebo, I presume the regular 3-Shoe variety will be available in the next day or so, would you be able to ship to the UK?
Cheers..
Ashalak is offline   Reply With Quote
Old 03-16-2009, 05:47 PM   #29
Steebo's Avatar
Yes, some of the tooling that I have coming was out of stock so it should be in by the end of the week.
Thanks,
Justin
www.impulse-rc.com
Old 03-26-2009, 08:25 PM   #30
Steebo's Avatar
Standard shoes are still on hold. Here's a little peek of the new D plate. Full line up of toe plates, motor mounts, center diff top plates and more on the way!
Impulse-r/c Clutch Shoe Review-picture-018.jpg
www.impulse-rc.com
