Old 03-01-2009, 06:38 PM   #1
rearviewmirror's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rearviewmirror Send a message via Yahoo to rearviewmirror
Default 8ight-T 1.0 Rear Diff
Is there a common problem with the ring/pinion in the 8ight-T 1.0 rear diff or outdrive? My truck is fairly new but today when hitting their brakes there was a loud grinding noise coming from the diff. I've not taken it apart yet, but it appears the rear diff is loose, you can wiggle it by moving one of the outdrives. I guess it could be bearings, or the plastic diff inserts. I did order the aluminum bearing carriers for the rear. Any thoughts? I pulled it off the the track immediately so I hope the ring/pinion is OK.
ARCTIC DOG RACING (Nitro free since 2009)
"Straights are for fast cars, curves are for fast drivers...."
8ight-E / 8ight-TE / T4 / Slash
rearviewmirror is offline   Reply With Quote
Old 03-01-2009, 06:58 PM   #2
vladconnery's Avatar
Trader Rating: 35 (100%+)
The inner gears are shot. When you take the diff apart your probally going to see pearlized diff fluid. Thats actually gears shavings cause you stripped them. The ring and pinion are going to be fine. More than like you were on power when you landed from a jump this will strip your gears everytime. Get a new set of inner gears there about $12. No big deal a common mistake also more than likely the center diff gears are stripped as well. This can happen to the front or rear depending on how you land. And it almost always strips the centers as well. When you land and are still on power. There is nothing to absorb the torque of the gears reengaging other than the gears themselves. It strips the landing wheels diffs and also send the excess torque to the center diff as well stripping those also.
KO PROPO EURUS
Kyosho: TKI3, TKIe Tekin RX8 Gen2
vladconnery is offline   Reply With Quote
Old 03-01-2009, 07:20 PM   #3
Thanks for the reply. I'm sure it's possible I was on the gas on a landing, I still drive like sh*t. I'll have to to pick up some internal diff planetary gears then and get ready to tear the diffs apart and replace what is needed. It's good to hear the ring/pinion should be OK, those are damn near $40 for the set and a pain to change.
Old 03-02-2009, 01:16 AM   #4
losi_racer's Avatar
Trader Rating: 25 (100%+)
ring and pinion are really simple to change, i never have stripped any gears in my truggy since ive had it so its not a common problem
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Losi 1/8 8ight E 4wd Thread tyhodge07 Electric Off-Road 8898 11-17-2015 05:31 PM
8IGHT 2.0! BAUSTIN Nitro Off-Road 14679 09-12-2015 07:58 AM
For Sale- Losi 8ight E 2.0 / 1.0 w tekin RX8 Doug T R/C Items: For Sale/Trade 17 05-09-2010 08:40 PM
8ight 1.0 Stability Issues Chris__RC Nitro Off-Road 16 06-08-2009 08:51 PM
Losi 8ight race roller everyjuangohome R/C Items: For Sale/Trade 8 05-08-2009 09:27 AM
