Old 02-28-2009, 05:06 PM   #1
Trader Rating: 27 (100%+)
Default 3pk users...help me out!!...lol
so i got myself a 3pk couple days back...been reading the HUGE manual lol and getting use to it...i do have a couple questions though...im running 2.4 fast...a local around me told me to use it on ppm...now ive been reading that if u have have digital servo's which i do (futaba bls351's) u should run it on hrs...the reason i want to run it hrs is because the fail safe...if u run it ppm there is no fail safe...so where should i have it???...also any tricks u guys know about let me know...this is certainly alot more in depth radio then my previous...thanks alot guys..also whats a good battery non lipo(no charger) to run instead of that garbage ni-cd it comes with..
mist467 is offline   Reply With Quote
Old 02-28-2009, 05:30 PM   #2
Set it in HRS and set your failsafe through the menu, although you can also utilize the failsafe when send in PPM I believe, or is it PCM?! Can't remember now been so long since I had my 3PK, but anyway you can use the failsafe outside of HRS its just set differently (Via the set button on the transmitter module), just read through your 2.4ghz addendum sheet.
Ashalak is offline   Reply With Quote
Old 02-28-2009, 05:54 PM   #3
yea its pcm and hrs u can use it in...i rather use it my radio in hrs mode..just making sure that ok...also its nicer in hrs because the fail safe also has the reciever failsafe always on and programed...i just wanted to make sure it was ok on hrs with my set up
Old 02-28-2009, 07:13 PM   #4
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
Set the radio the HRS mode if your running the Futaba digital servos. It will has quicker reaction time. Personally, I never set the failsafe on any of my vehicles. I haven't had a reason to use it.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 03-01-2009, 01:57 PM   #5
so any good battery recomendations??...anyone using the stickman rc battery???...
Old 03-01-2009, 02:39 PM   #6
ezveedub's Avatar
The stock battery sucks. I got a 2500 NiMh pack off of Ebay. They were two for $30 I believe. They last usually entire day's use or more.
Old 03-01-2009, 03:24 PM   #7
I've been using the HT Batteries lipo pack in mine..Its only a 1200,but it holds a charge for a month or so,and i race twice a week..
TLR|Horizon Hobbies|SpektrumRC|JConcepts|BradleyRacing|92zero|VRP|AceHardware|Tekin|TXDGraphics
CurtDawg is offline   Reply With Quote
Old 03-01-2009, 03:38 PM   #8
Anyone know anything about that Integy Autobalance Lipo for the 3PK?
Team HRC Raceway - http://www.hrcraceway.ca/
Semple is offline   Reply With Quote
Old 03-01-2009, 06:40 PM   #9
Trader Rating: 21 (100%+)
I'm using this lipo in my 3pk and 3pjs -
http://www.amainhobbies.com/product_...ducts_id/13503
For a non-lipo - these guys batts have been the best I've used -
http://www.ballisticbatteries.com/St...0&ProdTeaser=1
Duster_360 is offline   Reply With Quote
Old 03-02-2009, 02:57 AM   #10
hi! there good thing someone start this thread the futaba 3pk ,first of all i understand the manual ,i bought my new radio ( 3pks)last month n i cannot even go to the expert or level 3 mode pls. help..................thks
mbx5rcr34 is online now   Reply With Quote
Old 03-02-2009, 04:13 PM   #11
golferdude1971's Avatar
Trader Rating: 18 (100%+)
Try this battery from Team Helotes: http://www.teamhelotes.com/catalog/i595.html It's only $29 and they make a quality product.
golferdude1971 is offline   Reply With Quote
Old 03-04-2009, 12:59 AM   #12
finally ,i go through the level 3 (expert)but how come everytime i turned off this radio the level 3 is gone n then keep going to level 2 everytime ,pls. help is this normal?
