Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 02-28-2009, 07:52 AM   #1
jamiekerr14's Avatar
Default Edit-Hex tool spins inside of handle..???
Hey all, I got 2 Edit Hex tools.. an 1.5mm and 2mm I have a issue with them. If I try and tighten up and Hex.. I can get it reasonably tight, but then if I try to make it nice and tight.. the handle turn's but the Shaft dosnt.. so It wont tighten anymore, So I have to use a allen Key to tighten it up more. I have tightend the grub screw in the handle.. as hard as I can and still no difference, and Put some threadlock on and nothing.. what could be the issue??
Xray 808 09Spec
O.S. Speed+2060
Savox
Byron
DX3R
jamiekerr14 is offline   Reply With Quote
Old 02-28-2009, 08:14 AM   #2
SPEED37's Avatar
Is the set screw actually hitting the shaft? I would remove the set screw and pull the shaft out, if the set screw is touching the shaft there should be a mark. If the shaft is spinning against the set screw that mark will be all the way around.
SPEED37 is offline   Reply With Quote
Old 02-28-2009, 08:20 AM   #3
Now sorted, Found a new allen key.. and made them super tight.. now seems to hold.. thanks though!
Xray 808 09Spec
O.S. Speed+2060
Savox
Byron
DX3R
Old 02-28-2009, 08:45 AM   #4
scwrod's Avatar
I had a set screw actually break and would not grab the bit. I think it broke from over tightening. May have just been a brittle screw.
|18T| Micro-T| |2x Slash| |2x HPI E-Firestorm | 2x RC10GT | 2x GT2 | K8T-PTM NR P5XST
|RC8e Castle monster/2200 | Xray 808 - PTM NR Plus 4 | Losi L8ight - PTM NR P5XST | http://whitehousehobbies.com | http://protwistermods.com | Team Terribles
scwrod is offline   Reply With Quote
Old 02-28-2009, 10:10 AM   #5
losi_racer's Avatar
i loctite those screws as soon as i get new tools, make sure the spot that you tighten the set screw onto is flat
Losi 8ight-T 2.0/ Nova +4/ Ofna 053/
Losi 8ight-B 2.0/ Nova +4/ 9853
One Hobbies/ The Nitro Pit/SRS/ BCG Industries/ Team Terribles
losi_racer is offline   Reply With Quote
Forum Jump
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
