Old 02-28-2009, 06:51 AM   #1
Default Official GRP .21 non-tuned off road buggy engine thread!
I know I have a thread that still isn't off the first page but decided to do the trade so I have one of these engines now. This is just a thread to share your opinions on the engine as well as advice for fellow racers who have it. I know all the info I can get would be helpful to me and I think other guys will like it too.
rgrassey@me.com is offline   Reply With Quote
Old 02-28-2009, 09:08 AM   #2
Noones got this engine? Cant wait until mine comes!!!
Old 02-28-2009, 09:36 AM   #3
jkas10's Avatar
Trader Rating: 121 (100%+)
Check out Mark, At Powerhouse. His thread in in my signature. He has good information on these engines, and any other engine for that matter
Jeremy Kasten - Cole's Pitman! (Dad); Kasten Racing: www.facebook.com/kastenracing
THANK YOU Sponsors: Mugen Seiki; REDS; AKA; Leadfinger Racing; NitroPro Fuel; RC Addiction Products; Dialed-RC Hobbies; Ben Brocato Designs (BDB); PT RC Racing Oils
jkas10 is offline   Reply With Quote
Old 02-28-2009, 09:46 AM   #4
mikenix's Avatar
Trader Rating: 21 (100%+)
I now have both the tuned and non tuned. I can't figure out which one is faster! I had the non tuned first so it might just be the amount of time I've had with it. I'm using the OS LC3 plug with the non-tuned and it loves it.
www.answer-rcusa.com
Contact me for details.....
When you sling mud, you only loose ground. - Fat Albert
mikenix is offline   Reply With Quote
Old 02-28-2009, 10:14 AM   #5
sounds great guys what type of runt times are you seeing? Also should I be running cold medium or hot plugs with it?
Old 02-28-2009, 01:16 PM   #6
Frank L's Avatar
Trader Rating: 148 (100%+)
I have always used a med plug but recently decided to try an OS P3 hot plug. So far I am digging the hot plug. It seems to start easier once I hit the engine with the heat gun and it idles better too. I converted my GRP to take turbo plugs (just my personal preference no real advantage).
Old 02-28-2009, 02:35 PM   #7
so can I get some odonnel hot pluga
Old 02-28-2009, 03:34 PM   #8
mikenix's Avatar
The LC3 that I'm using is hot. I'm getting about 11mins run time using it in a 808 with a 6mm insert and a TTR2035 pipe.
Old 02-28-2009, 03:46 PM   #9
Mack_Mechanic's Avatar
So the non-tuned version uses standard plugs?
Steve Arms
www.rcracebarn.net
There is no such thing as too much motor....just not enough driver!
Mack_Mechanic is offline   Reply With Quote
Old 03-01-2009, 06:03 AM   #10
mikenix's Avatar
Yes standard long reach plug and it uses a head button, if memory serves the tuned is a single piece for the cooling head and button are one piece.
Old 03-01-2009, 08:05 AM   #11
Davidka's Avatar
Trader Rating: 75 (100%+)
Not really on topic but related: With non-turbo engines .21's always use cold to medium plugs, with turbos it's always hot. Are they just a different calibration? I though I'd ask here because GRP's seem to be used by the same people both ways.
Old 03-01-2009, 09:18 AM   #12
air8's Avatar
The plug button is part of the cooling head right?
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 03-01-2009, 09:31 AM   #13
the non tuned has a one piece head so you cant just change the button to turbo. the non tuned GRP's that are modded by Powerhouse have proven to out perform the tuned one. The special he has going right now he has GRP's modded for $280, which is cheapere then the tuned yet still outperforms it. I ran mine last night and swear by it now. It was set rich b/c it was being broken in but had power eveywhere and held its tune. If you were looking at getting a GRP i strongly suggest giving this modded motor a look.
www.powerhousercperformance.com
www.coldfusionrcproducts.com
Fierle03 is offline   Reply With Quote
Old 03-01-2009, 09:33 AM   #14
So I was thinking I would get some medium plugs. Also will inserts come with the engine? Just to make sure because I am new and insert is something you put into the carb to not allow you to go to full throttle to save fuel correct?
Old 03-01-2009, 02:50 PM   #15
