Old 02-27-2009, 11:15 AM   #1
markr04's Avatar
Default Is there a way to test the accuracy of a temp gun?
I have a little Ofna-branded one (they're also branded under other names). It measures 20f cooler than another one I have. A buddy has the same Ofna one I have and it measures higher than both of mine. Another buddy has a different model that measures about the same as my Ofna one.
Way too many measurements that are 20f difference.
Is there a way to test the accuracy of a temp gun? Would measuring boiling water (100c/212f) give me an indication? Anyone tried this?
Xray 808 2010 Spec - O.S. V-Spec Speed - Airtronics M11-DSSS
Losi 8ight-T 2.0 - RB Killer 9 - Airtronics M11-FHSS-2
Losi XXX-CR - Tekin RS / Novak Ballistic 13.5 - Airtronics M11-FHSS-2
markr04 is offline   Reply With Quote
Old 02-27-2009, 11:21 AM   #2
rearviewmirror's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rearviewmirror Send a message via Yahoo to rearviewmirror
Boiling water does work.
ARCTIC DOG RACING (Nitro free since 2009)
"Straights are for fast cars, curves are for fast drivers...."
8ight-E / 8ight-TE / T4 / Slash
rearviewmirror is offline   Reply With Quote
Old 02-27-2009, 11:24 AM   #3
esridge's Avatar
Trader Rating: 10 (92%+)
Find someone with a Exergen temp gun and compare yours to that.
www.tilted1.com , www.tiltedrc.com , Tilted Fuel , Team Terribles
esridge is offline   Reply With Quote
Old 02-27-2009, 11:36 AM   #4
I did this and found that my $70 temp gun reads exactly the same as the Exergen.
-TKO Competition Development-Sidewinder Fuel-
Alan D. is offline   Reply With Quote
Old 02-27-2009, 11:42 AM   #5
RacerScott's Avatar
I did this with my raytech and the "rayjunk" was 10 degrees cooler, not bad. But my friend has the same model raytech and his measures 40 degress hotter than mine
VP powermaster fuel | Upgrade RC
Scott U.
RacerScott is offline   Reply With Quote
Old 02-27-2009, 03:21 PM   #6
jyfz2's Avatar
make sure the tip of you gun is clean this will make a big difference use a q-tip to clean it dust and oil on the tip will hurt accuracy big time
jyfz2 is offline   Reply With Quote
Old 02-27-2009, 03:55 PM   #7
Trader Rating: 36 (100%+)
Boiling water can be used but remember that the boiling point of water depends on your altitude. At sea level it is 212, at 2000 feet it is 208, and at 5000 feet it is 203. Barometric pressure will ever so slightly affect the boiling point as well but not as much as the altitude differences.
Sabre X3 V2
Losi 8ight 2.0
Losi 8ight 2.0 e
rstnboy is offline   Reply With Quote
Temp guns... again D_o_S Nitro Off-Road 26 07-25-2007 12:15 PM
