Old 02-26-2009, 04:53 PM   #1
Default Nitro Fuel
What is the maximum percent of nitro fuel out there? I.E.. 50% nitro, 60%, etc... I need to know who the manufacturer is as well. Thanks.
fitz101 is offline   Reply With Quote
Old 02-26-2009, 05:31 PM   #2
porkey's Avatar
The more nitro the more your piston will be lubed. That means more rpm and more motor wear. Now this from what I heard.
porkey is offline   Reply With Quote
Old 02-26-2009, 05:39 PM   #3
Chill_Will's Avatar
Trader Rating: 32 (100%+)
Are you going to use it in a car or truck motor? If you are can you say kaboom! It's not recomended in a car or tuck.
A-Train racing (Woooooo Wooooo!!)
Chill_Will is offline   Reply With Quote
Old 02-26-2009, 05:46 PM   #4
GregH's Avatar
Send a message via AIM to GregH
Chops, what the heck are you talking about? The more nitro doesn't mean more lube.
GregH is offline   Reply With Quote
Old 02-26-2009, 07:15 PM   #5
Zerodefect's Avatar
???!!!!1
All kinds off crazy here! Let me get on my rocking horse.
50% Nitro is used in nitro boats. You have to drop the compression of the engine and time the intake and exhaust ports real close to make it work. Racing only.
Not a good idea, It'll kill your engine. Rc cars are 30% tops.
Airplanes use very low nitro %. 0-15. Those engines are relatively detuned compared to race engines. Thats why they last forever. If you need more power you build the plane for a larger engine, not stuff more nitro in. Even if the prop keeps the engine cool you still need the proper mixture, plug, and port timing. Sport planes use low nitro. Never seen a racing planes engine, because they are lame.
Nitro is mostly just an oxidizer. It deosn't lube anything.
DO NOT USE 50% IN YOUR CAR!1!
Zerodefect is offline   Reply With Quote
Old 02-26-2009, 07:33 PM   #6
rearviewmirror's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rearviewmirror Send a message via Yahoo to rearviewmirror
ARCTIC DOG RACING (Nitro free since 2009)
"Straights are for fast cars, curves are for fast drivers...."
8ight-E / 8ight-TE / T4 / Slash
rearviewmirror is offline   Reply With Quote
Old 02-26-2009, 07:38 PM   #7
Marcus Falconie's Avatar
Odonnell makes 50 and 60% boat fuel or you can find out who your local VP dealer is and they sell 100% nitro for drag racing but I think you can only order 22 & 1/2 or 55 gallons
Marcus Falconieri
2011 Xray 808
Torco Racing Fuels
KBRL Nitro Series
www.youtube.com/gsadvanced
Marcus Falconie is offline   Reply With Quote
Old 02-26-2009, 07:39 PM   #8
karnao's Avatar
Is anyone actually going to answer his question?
karnao is offline   Reply With Quote
Old 02-26-2009, 08:01 PM   #9
It has been answered. Nitro is available up to 100%. Nitro has nothing to do with lubing anything. In fact, nitro is the worst thing in your motor. Its corrosive, it attracts moisture to the steel parts. The more percentage you have the bigger explosion, so you have to lower compression to prevent detonation and knocking.
The big advantage of nitromethane is that you can get a lot more power from each explosion inside the engine. Pound for pound, nitromethane is less energetic than gasoline, but you can burn a lot more nitromethane in a cylinder. The net result is more power per stroke. You typically need about 15 pounds of air to burn 1 pound of gasoline, whereas you need only 1.7 pounds of air to burn 1 pound of nitromethane. This means that, compared to gasoline, you can pump about 8 times more nitromethane into a cylinder of a given volume and still get complete combustion. (web searched)
R/Cs are two stroke nitro burners, there is oil mixed in the fuel you buy. However, the nitro is still there with its properties so it attracts some moisture and its corrosiveness eats on your bearings and parts, so that is why its a good idea to ARO your engine after each days use. The oil doesn't necessarily STICK to the parts in there, it just lubes during use.
My .2cents.
Clay Grantham
TLR 8ight 3.0/Futaba 4PLS/WERKS B5 .21/VP Fuels
motoclay is offline   Reply With Quote
Old 02-26-2009, 08:58 PM   #10
Airplane racing engines used to run on 60-70% nitro fuel. They no longer do this but still make insane power on 15% or 0% FAI. If you think airplane racing engines are lame go check out a good Q40 or FAI race. The engines are .40cid and move the planes close to 200mph on a 1/4mile triangle course.
Addiction RC
Scott51 is offline   Reply With Quote
Old 02-26-2009, 10:14 PM   #11
Thanks guys. My question has been answered. I suppose I should have stated my purpose. Long story short, got some lower percent nitro fuel, want to mix with some higher to make it around 20%. Thanks again.
Old 02-27-2009, 12:20 AM   #12
My .2cents.
It's not a explosion inside the engine it's controlled burn because it's under pressure. It has a flame front that burns across the combustion chamber. It doesn't light off like a stick of TNT "BOOM"
pdmustgt is offline   Reply With Quote
Old 02-27-2009, 01:22 AM   #13
triplesix's Avatar
BE CAREFUL!
You cannot mix every fuel 'cause there are synthetic oils that should never be mixed with others! You could seriously damage your engine. I'm not saying you WILL, but you COULD.
triplesix is offline   Reply With Quote
Old 02-27-2009, 05:54 AM   #14
Zerodefect's Avatar
Just not my cup o tea. I get a kick out of the 50cc gas engines. Especially a Yak 54 that can hover.
As someone else mentioned nitro engines use less air per pound of fuel than gas. Thats cause the nitro is , more or less, liquid air. Its the oxidizer for the fuel. Less air is needed.
What exactly do you want to do with 50% fuel anyway.
Old 02-27-2009, 06:19 AM   #15
In Europe they run with little to no nitro due to EPA requirements. They run on straight methanol and oil.
Nitro On-Road Addict sa RC Manila Racers 12522 12-27-2015 05:51 PM
RC news at Kuching evoton Malaysian R/C Racers 827 11-05-2013 09:37 AM
Food for Thought - Cheaper to run Thopper Electric Off-Road 38 12-22-2008 07:52 PM
GS CUP Malaysia 2008 jets Malaysian R/C Racers 328 07-08-2008 08:40 AM
GOOD FUEL scarlet Nitro On-Road 147 03-10-2007 08:41 AM
Losi LST or Traxxas Revo INVIZAGOD Monster Trucks 216 06-09-2005 07:03 AM
Wanted- Hpi Nitro Any Kind Post Here! dizboihuy R/C Items: Wanted to Buy 6 03-21-2003 05:30 AM
