Old 02-26-2009, 05:25 AM   #1
ffpm46's Avatar
Trader Rating: 164 (99%+)
Default EB Mods GO 5 port EBM5 Full Mod
Does anyone own one of these? Just picked one up and so far so good, this is my first venture from V-SPec and was curious on the longevity of this motor. Also if anyone ran into any problems with it.
ffpm46 is offline   Reply With Quote
Old 02-26-2009, 12:24 PM   #2
PinoyCali's Avatar
Bump.
PinoyCali is offline   Reply With Quote
Old 02-26-2009, 03:19 PM   #3
chim13's Avatar
Trader Rating: 25 (100%+)
these motors are top notch mills, check out the go tech thread for more info if taken care of will last for a long time
Mugen MBX7r, MBX7T,MBX7r Eco
SPONSORS
Mugen Seiki, AKA, Amain Hobbies,
Power Master Fuel, Stickit1 racing, Lucky7 Products,
chim13 is offline   Reply With Quote
Old 02-26-2009, 04:28 PM   #4
Most people around here complain about the carb alot. It sounds like you are past that, so good luck. They do make good power.
SPEEDSKI is offline   Reply With Quote
Old 02-26-2009, 05:16 PM   #5
zJatoRad's Avatar
Trader Rating: 31 (97%+)
Send a message via MSN to zJatoRad
I rarely see anyone complaining about the carb after the Gen 5 engines came out.
I'm running the stock 5 Port and I'm getting 10 mins a tank with the 0801 pipe, running a 14T clutch bell and getting power everywhere, I can't imagine what the EBM5 can do! that's definately going to be my next engine
"Smooth is Slow, and Slow is Fast"
zJatoRad is offline   Reply With Quote
Old 02-26-2009, 05:21 PM   #6
burnettk's Avatar
yea the stock makes power. when i rebuild them i replace the carb with a grp carb. i have had problems with air leakson them. keep a check on the o rings around the carb.
burnettk is offline   Reply With Quote
Old 02-27-2009, 02:34 AM   #7
ffpm46's Avatar
Thanks everyone, one thing Ed does is replace the stock O rings with better ones, then flow tests the carb.
First race with it this Sat
Old 02-27-2009, 07:53 AM   #8
Tony Newland's Avatar
Trader Rating: 50 (100%+)
basic specs additional to stock specs on the EBM engines:
FM - Fully Modified -
Fully Modified engines come Fully Broken-In and Ready to Race. Modified engines come with Blueprinted parts and are Hand Built in the USA. Modified Engine parts are machined and modified to increase peak power and broaden the usable power curve. Crank Shafts are Bored and filled to improve inertia weight and balance. Modified engines also include TKO Rear Ceramic Bearing, TiN coated Crank Shaft, Wrist Pin, and Carburetor Slide. Every Carburetor is inspected, flow checked, and then tuned with engine to assure performance
RP - Race Prepped - The engine Matt Gosch used to win Motorama last weekend
Race Prepped engines come Fully Broken-In and Ready to Race. Race Prepped engine are Matched and Hand Built in the USA. Every engine includes TKO Rear Ceramic Bearing, TiN coated Crank Shaft, Wrist Pin, and Carburetor Slide. Every Carburetor is inspected, flow checked, and then tuned with engine to assure performance.
Schumacher Factory Team - Core RC - Highest Servos - Avid - Lunsford - Bellgate Distributors - Jconcepts - www.Prime-hobby.com - IRCR
Tony Newland is offline   Reply With Quote
