Old 02-25-2009, 02:27 PM   #1
Hitman Racing 1's Avatar
Default What diff oil comes in the losi 8 rtr?
Just got mine broken in and when i go to track i'd like to know weather I need to go up or down in wt.
Hitman Racing 1 is offline   Reply With Quote
Old 02-25-2009, 02:29 PM   #2
grease comes stock
rgrassey@me.com is offline   Reply With Quote
Old 02-25-2009, 02:30 PM   #3
jrwoodchuck's Avatar
none, it comes with grease in the diffs. but i used 5-7-2 in my eight.
Doug
TLR 22/M-11
“Looks like I picked the wrong week to quit sniffing glue.”
jrwoodchuck is offline   Reply With Quote
Old 02-25-2009, 02:33 PM   #4
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
+1
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 02-25-2009, 02:44 PM   #5
So that grease is not on just the outside gear? I was told there should be oil on the inside ones? I'm new to buggies any help for a dummy is appreciated.
Old 02-25-2009, 02:55 PM   #6
Location: movin to the big time. on my way to the bay next week!
Trader Rating: 11 (92%+)
yes there should be oil inside the planetarium gears. but it does not come stock on the rtr's. once you open it up, you will poor out black gunk, that is the grease. you need to clean that all out very well and the fill them up with diff oils. the standard set up is 7000, 5000, 2000. that is a really good setup for most tracks
sgodwin85 is offline   Reply With Quote
Old 02-25-2009, 02:58 PM   #7
Trevor Williams's Avatar
Trader Rating: 195 (100%+)
They are lightly grease filled, clean all that out really well as previously stated. I would start with 5-7-2 or 3 then fine tune to your driving style/track conditions from there. make sure not to overfill the diffs with the fluid, fill it up, then work the gears so it will settle, then top it off to just be over the diff gears, you dont want leaky diffs from over filling.......Use Mobil1 red grease on your ring and pinion gears(axle/bearing grease in a giant tube for $8 @ any auto parts store that will last a lifetime)
RC10-B6d | RC10-B64d
SmacTrac
#WeAreAE #ReedyPower #AE4Life
Trevor Williams is offline   Reply With Quote
Old 02-25-2009, 03:02 PM   #8
Good deal thanks guys... So any tips on cleaning the grease out of those diffs?
Old 02-25-2009, 03:08 PM   #9
pick up some Naptha(petroleum ether) @ Walmart or paint store(be prepared to show ID for this as people use it for other things), then You put the differential parts in a jar with naptha in it for 20-30 seconds, swirl around, then dump them out, wipe/dry off, re-fill with fluid of choice then re-assemble. Also make sure to check all o-rings, bearings etc. in diff assemblies since you are there.
SmacTrac
Old 02-25-2009, 03:12 PM   #10
Thanks Trevor... Your the man.
Old 02-25-2009, 03:17 PM   #11
your welcome
SmacTrac
Old 02-25-2009, 05:39 PM   #12
dishsoap's Avatar
When you service the diffs take it slow and remeber where each part is before taking it off. Give yourself 4 hours or so for the 1st time to complete this task. I am newer as well and it took me 5 hours to do all 3 diffs. I would also recommend having the manual handy so that you can reference where the part go if you forget.
The actual cleaning, rebuilding, and filling process is easy. What takes alot of time is putting everything back together.
Have fun and take it slow.
I went with 5 7 5 and it is way to agressive for me. I am having trouble with the back end spinning out and turning forget it.
HobbyTown USA Tucson!!! HobbyTown USA SRS!!!!
dishsoap is offline   Reply With Quote
Old 02-25-2009, 05:57 PM   #13
Woa.....5 in the rear diff!!!??? I would start with 2 or 3 in the rear.
Losi 8ight 1.5 ~ 8T ~ XXX Buggy ~ Mini-Baja
The o''le saying goes, pay me now, or pay me later, because you gonna pay me. "Pearl_414"
Chris__RC is offline   Reply With Quote
Old 02-25-2009, 07:15 PM   #14
BOOST's Avatar
No wonder you are having trouble...I recommend you two should try 3/5/2. That would make the buggy fairly easy for you to drive. 5 is too thick for the rear.
BOOST is offline   Reply With Quote
Old 02-26-2009, 12:43 AM   #15
losi_racer's Avatar
Trader Rating: 25 (100%+)
i use 5/ 5/ 3 in my 2.0, but i plan on puttin the smart diff in
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Getting started:Tip's,Trick's,Newbie's come here! xsxracing Rookie Zone 59 01-03-2009 09:57 PM
Blow Out Sale....... Factory Seal R/C Items: For Sale/Trade 20 07-03-2008 04:41 PM
Will Electric buggies perform as good as nitro buggies? RCn00bHelpMe Electric Off-Road 46 02-06-2007 09:58 PM
FOR THE NEWBIES!!! IF YOU ARE NEW READ THIS omaharich Electric On-Road 54 01-18-2007 01:32 PM
Considering some OFNA/CEN Buggies TxCZShooter Electric Off-Road 28 01-17-2007 07:01 AM
