Old 02-25-2009, 06:54 AM   #1
kpsscamaro's Avatar
Default stampede bubbles form in fuel when hot
like the title says bubbles form when engine in warmed up and i stop to refuel. now when cold it primes fine but when hot cause of air eng. wont start as buubles form to quickly and takes priming while turning over engine to start.once started it runs fine till to next pit stop. Anyone have any ideals one whats going on
kpsscamaro is offline   Reply With Quote
Old 02-25-2009, 07:10 AM   #2
GregH's Avatar
Send a message via AIM to GregH
Replace all the fuel line and try again. I've seen brand new fuel line have tiny pin holes that allow air in but won't let fuel leak out. A issue like this, I would replace all line and try again.
GregH is offline   Reply With Quote
Old 02-25-2009, 07:59 AM   #3
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
If you have the fuel line really close the the engine head like how they come from factory this will heat up the fuel and create air bubbles . If this is the issue route some new fuel line so it stays clear of the engine head .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 02-25-2009, 08:35 AM   #4
joe of loath's Avatar
might be bubbles caused by the fuel sloshing around. If it still happens after you've replaced and rerouted the lines, ignore it.
HPI E-Firestorm - Tamiya TA05 racer (carbon chassis, 10.5 brushless etc) - LRP Blast S10 BX - Revo 2.5r truggy conversion (in progress)
joe of loath is offline   Reply With Quote
Old 02-25-2009, 09:10 AM   #5
kpsscamaro's Avatar
Thanks guys i wasnt sure how easy the fuel would vaporize in the line.The bubbles appear at the point close to the head and carb.
