Old 02-25-2009, 10:12 AM   #16
DriftProjectR's Avatar
Trader Rating: 38 (100%+)
Originally Posted by rearviewmirror View Post
Do all of you soak in acetone? Do you buy it in bulk? 1 gallon at Lowes is like $16.
go to a commercial hardware store. 5 gallons is 24 bucks where im from.
Hot Bodies IFMAR Worlds
OS Engines
Ace Servo
BCE Design
Bodies By Scott
Lungsford Titantium
M2C Racing
DriftProjectR is offline   Reply With Quote
Old 02-25-2009, 10:47 AM   #17
Originally Posted by John Schafer View Post
I bake my tires off.
Heat oven to 350. When burner/element shuts off put tires in oven. After about 15 minutes pull them out. Using gloves seperate the tire from the rim. If some areas are still bonded repete procces. Don't know if some of the newer molded foams can handle that much heat but the older cut foams actually come out good as new.
NOTE: If your wing or another plastic part is deformed, you can also place it in the oven and it will return to it's original shape. Boiling them also works.
+2
Used to boil them, but it takes forever.
I replace the foams either way.
MBX-6
Caster MK2 / N21BF / P5XLT H.E.S.
casevac is offline   Reply With Quote
Old 03-01-2009, 01:11 PM   #18
badjams's Avatar
should i soak the whole tire/wheel in acetone or just the bead area? could i just set the tire /wheel on a rack in the bucket of acetone with a lid on it overnight and let the fumes do the work? also will the tire still be ok to reuse , like clay or soft compound tires for example??? thanks
badjams is offline   Reply With Quote
Old 03-01-2009, 01:44 PM   #19
bcrazy's Avatar
I tried acetone with my 10th scale tires. I took forever and actually shrank my clay compound tires.
Brian Branson Thank you Team Associated, Reedy, LRP, JConcepts, Byron Fuels, & Fastlane Graphix for your support in 2012 Paint by KustomRCGraphics kustomrcgraphics.com
ROAR Region 10 Director Arizona, Colorado, New Mexico, Utah, Wyoming. roarracing.com
Thank you to every track owner and or club president for giving racers like me a place to race.
bcrazy is offline   Reply With Quote
Old 03-01-2009, 02:40 PM   #20
pballer2777's Avatar
Trader Rating: 27 (100%+)
i did the acetone thing and all i was able to reuse was the rims. so if u r looking to save the tires this didn't work well for me. it will definitly ruin the foams. if u r looking to save tires, rims or foams boiling is the way to go. u can reuse all three.
pballer2777 is offline   Reply With Quote
Old 03-01-2009, 03:09 PM   #21
pinky2252s's Avatar
Send a message via AIM to pinky2252s Send a message via MSN to pinky2252s
Boiling saves all three
I used acetone for the first time a few weeks ago when i had to replace a foam, i filled it up and only about one tire was covered in my can but i figured out that its really the fumes that do most of the work.
So all you have to do is use some sort of SEALING can that can fit your wheels (either that or like 4 small cans it really doesnt matter) and just pour in and let sit for about 24 or 36 hours and they come off pretty gooey but it works REALLY well.
Procrastinators Unite!.....Tomorrow
Team Terribles
pinky2252s is offline   Reply With Quote
Old 03-01-2009, 04:54 PM   #22
superdave2's Avatar
im realy susprised that somebody hasnt made up a type of remover just made for ca glue that totally (dissolves) the glue and only the glue and it dosent take all nite now ive never used the acetone trick but ive done the boiling trick and it didnt work too good i had that tire in there for ever the and i could not get the tire and rim to separate from each other so really didnt know what to do after that i just kind of put the tires away until i try something diffrent
Team Terribles~ARCS Hobbies~Have Fun Hobbies~Answer-RC~Torco Fuel~Fastlane Graphix~ Caster Racing Products~Maxamps~Clockwork Racing Engines~BCG Industries
losi 8t dps .28 jr z9100s jr z9000t
spektrum dx3
superdave2 is offline   Reply With Quote
Old 03-01-2009, 05:03 PM   #23
Im a VERY messy gluer, so I always have nail polish remover in my grasp whenever I glue my hands together with CA glue. I have never tried this, but would nail polish remove (Losi CA debonder is the same thign right?) the CA glue from the rims?
Losi 8ight 1.5 ~ 8T ~ XXX Buggy ~ Mini-Baja
The o''le saying goes, pay me now, or pay me later, because you gonna pay me. "Pearl_414"
Chris__RC is offline   Reply With Quote
Old 03-01-2009, 05:11 PM   #24
burnettk's Avatar
Originally Posted by GregH View Post
Just what he said. I forgot to mention you need to flip the tire. It floats so.....
Boil them and once their off the wheel, clean them up some and your ready to glue them on a different wheel.
When I started racing, I use to try and remove the tires off the wheels. It got to be a major PITA and I would just buy new wheels and tires. Now I have about 100 sets of tires, some still like new, others bald as a babies bottom.
By the way, I don't race anymore so I have all these tires piled in a box. I'll probably toss them in the garbage.
are they buggy tires? i will pay the shipping to take them off your hands lol.
burnettk is offline   Reply With Quote
Old 03-01-2009, 06:31 PM   #25
omarwashington's Avatar
will boiling tires/wheels warp the wheels?
omarwashington is offline   Reply With Quote
Old 03-01-2009, 06:33 PM   #26
i've boiled about 10 sets and reused the rims. i have never had a rim warp.
Old 03-01-2009, 06:34 PM   #27
bgbelden's Avatar
1 quart of Acetone is 6.75 at Wal-mart, pour about 1" in the bottom of a coffee can and put 3 tires in then cover and in a day or two your good as new.
The foams only get ruined from the actual liquid so i raise my rims off the bottom so only the fumes does the work, i've got 2 V3 rimes tires and foams i will be re-glueing tomorrow that i used this method on.
The same Acetone has been used for about 15 tires without having to use anymore so i've actually spent very little money.
''Life's tough ........
it's even tougher if you're stupid..''
-- John Wayne
bgbelden is offline   Reply With Quote
Old 03-01-2009, 08:15 PM   #28
pinky2252s's Avatar
Well they cant make anything more powerfull on CA glue then acetone, its the opposite/solvent of CA, the only one
Team Terribles
Old 03-02-2009, 03:49 PM   #29
superdave2's Avatar
so the acetone totally dissolves the all of everybit because like i stated above ive never used it before so i dont know if it only takes some of it off or all of it and by raising the tires off the acetone saves the foam but i do have quite a few tires that are junk
spektrum dx3
Old 03-02-2009, 05:18 PM   #30
pinky2252s's Avatar
Well it more or less makes it gooey and unsticky so it just comes off the rim
Team Terribles
how to remove rubber tires already glued on rims? Molala3 Electric On-Road 34 05-11-2016 09:33 AM
FAQ's for VTA wiscnitro Electric On-Road 27 09-17-2009 05:55 PM
Blow Out Sale....... Factory Seal R/C Items: For Sale/Trade 20 07-03-2008 04:41 PM
How to unglue..........glue? K_King Electric Off-Road 24 01-22-2007 12:36 PM
NEED HELP>getting glued tires off of plastic rims old_fart_racing Electric Off-Road 16 09-21-2006 09:13 PM
