Old 02-25-2009, 12:17 AM   #1
Default hyper 8.5 spyder diff
Just want to know about front/rear diffs on the hyper8.5's, ive almost finished my conversion except for this.
Will it make much difference changing it over to the spiders diffs?
glyde is offline   Reply With Quote
Old 02-25-2009, 12:20 AM   #2
dont do it its not worth it spider gears are desined to run on a little bit of grease with oil in em they just lock up and dont do there job properly
nover367 is offline   Reply With Quote
Old 02-25-2009, 08:02 AM   #3
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
There is nothing wrong with using spider gear diffs and they do not use grease and oil , just regular diff oils .
Nover367 , sounds like you are thinking of Torsen diffs .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 02-25-2009, 08:13 AM   #4
zJatoRad's Avatar
Trader Rating: 31 (97%+)
Send a message via MSN to zJatoRad
I don't think it's a neccesary to change, when I had my H8.5 I preferred to use a standard center differential from a H8 than the spider.
"Smooth is Slow, and Slow is Fast"
zJatoRad is offline   Reply With Quote
Old 02-25-2009, 02:55 PM   #5
Why do you say that? Ive got the spider centre diff and using the standart front/rears I didnt have much run time on the standard centre diff and just wondering what differences you found
Old 02-25-2009, 03:14 PM   #6
If I was you and lived in Europe i would look for an xray xb8 ec. They are great for the european style tracks and are pretty much bullet proof for bashing! All the best.
roots is offline   Reply With Quote
Old 02-25-2009, 03:24 PM   #7
I liked the spider center once I got it thru my head that it required silicone 1,000 to 2,000 less than the normal diff becasue the 2 extra gears created a slight extra drag. Did not try a spider in the front or rear. When its right its very smooth, no slop and strong as a diff can be.
Ed M.
bentgear is offline   Reply With Quote
Old 02-25-2009, 10:56 PM   #8
zJatoRad's Avatar
well simply because it tunes different than the standard, it's just a matter of preference.
Old 02-26-2009, 01:02 AM   #9
no dude i was talkin about spider good as normal diffs because they lock up they dont work properly with oils a smeer of grees is wat u should use other wise ur just runnin a very tight or locked diff
Old 02-26-2009, 09:16 PM   #10
whenever possible I like to use the spider diff up front. The reason being because of the 2 extra gears the silicone tends to spool up more. For example if I put 5k oil... off power i get 5k but when on power while accelerating it acts like I have 7k. So more steering all throughout the turn
Genius is offline   Reply With Quote
Hyper 8.5 Pro , Big bores, Many extra parts. Backpain R/C Items: For Sale/Trade 15 11-09-2008 05:33 AM
GARAGE SALE! (large pic) XXWoodmanXX R/C Items: For Sale/Trade 33 09-22-2007 05:03 PM
getting out of rc 2mcgrath R/C Items: For Sale/Trade 41 08-11-2006 05:39 PM
F/S F/T : Emaxx, FT RC10GT, Tmaxx, Raptor nitrorocks R/C Items: For Sale/Trade 57 12-01-2005 05:32 PM
