Old 02-25-2009, 11:41 AM   #16
Trader Rating: 14 (100%+)
I have no shims between the flywheel and the engine. I did notice that the collet has about 2mm of space to the back side when the flywheel is tightened down all the way. I could cut that down, but then the flywheel would touch the engine.
I only put one shim in between the flywheel nut and the bearing of the clutch/gear. Even if I take that out though, the gap isn't enough to make it work.
I ordered the shim kit today. Hopefully that will cure my problem. If not, I'll start trimming parts down until it works.
fatwreck is offline   Reply With Quote
HPI MT 2 converting to electric question Tom P Electric Off-Road 35 08-16-2004 07:49 PM
