Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 02-24-2009, 05:44 PM   #1
Marcus Falconie's Avatar
Default New ORION ALPHA 3-PORT
Can't wait for this motor to come out, it looked super fast and smooth at the Nitro Challenge and Cody King set early TQ with it. I was told it is Sirio based not Picco but Orion will have both. The case did not look like any other Sirio I have seen and neither did the carb.
Marcus Falconieri, Team terribles, ET Moto Park, SRS, and the The Nitro Pit
Torco racing Fuel
www.youtube.com/gsadvanced
Marcus Falconie is offline   Reply With Quote
Old 02-24-2009, 07:18 PM   #2
pitpop's Avatar
Hi Marcus, thanks for starting this thread, great idea. I will be in here sharing as much as possible about the new engine. Of course we are very pleased with it thus far. Our engines are not production but it won't be long until we have a part number. We got VERY good mileage in qualifying, with enough fuel to easily go 10 minutes. For some reason in the main the mileage went down. I think I had the tune a little fat. In any case, we had to pit early, but I have no doubt we will hit the 9 minute pit mark soon. In order to go 9, you really need to be able to go 11, so that is our goal, 11 minutes with race conditions. We ran a Sirio #6 turbo plug and OS 2050 pipe. I have been told we will have a full compliment of pipes and plugs as well.
Also, we ran the Orion Alpha ABI (Adrien Bertien Influenced) .24 five port in the truggy, and that thing was unreal. SO much power and we were able to go 9 minutes on fuel without any trouble. Cody won the high jump contest with that engine. You need allot of power to launch the truggy 20 feet vertical!
Cody's Wrench, Kyosho International, Team Orion, AKA Tires, KO Propo,
Byron Fuels, Lunsford, UpgradeRC, DarksideDesigns, AMAINHOBBIES.com
pitpop is offline   Reply With Quote
Old 02-24-2009, 08:55 PM   #3
alexzone007's Avatar
Default hi
the orion alpha looks very impresive in tebo and cody cars @ the nitro chalengue
i would like to know if the .24 its a good one for a truggy cause everybody always use a .21 but i ike it
i have a new lrp .21 would like to know is there is some similaryty in those engines
alexzone007 is offline   Reply With Quote
Old 02-25-2009, 12:23 AM   #4
Just to clarify, Jared was not running the Alpha series prototype engines. The weather didn't give him a chance to get the engines broken-in and to become comfortable with the driving characteristics before the race. He was running the US Spec Orion .21 engines.
Cody was running the Alpha .21 3-port ABI in buggy and the Alpha .24 ABI engine in truggy, and Cavalieri was running the Alpha 3-port ABI in both buggy and truggy, the latter of which he used to win the A-main at the Nitro Challenge. The Alpha series has very smooth power delivery and excellent fuel economy. It's quite promising based on the initial results.
SteveP is offline   Reply With Quote
Old 02-25-2009, 12:35 AM   #5
Can people use OS P3 plug on the Alpha line? Thx
AndyItalia68 is offline   Reply With Quote
Old 02-25-2009, 02:11 AM   #6
isn't the Alpha .24 the same as the sirio built Extech .24 ?
Maximo is offline   Reply With Quote
Old 02-25-2009, 04:37 AM   #7
Trader Rating: 20 (100%+)
Hey Pitpop
I know you guys were under the gun but were any other pipes tested with the motor?? I have been particular to the jp series so I was just wondering..
thanks
MO
Mo Denton
If its good I'll tell you
If its Junk I'll tell you that too..
who cares who it offends.
1fastguy1 is offline   Reply With Quote
Old 02-25-2009, 04:50 AM   #8
Echelon's Avatar
I'm also curious about the new Alpha line.
How will it compare to the picco based CRF line? (price, performance)
Echelon is offline   Reply With Quote
Old 02-25-2009, 08:44 AM   #9
Yes, the Alpha ABI engines are coming with an insert made for use with "turbo" glowplugs. A P3 would be a good choice, as well as a Team Orion 5 or 6.
I have to imagine there are similarities, but at first glance, the block is not the same as the Sirio. I don't have an Extech engine, and I have yet to measure all the timing events of either engine. Once that is complete, then I will be better able to answer your question.
The prices look like they will be comparable between the two engine lines. As for performance, the Alpha engines appear to have much smoother power dlivery and better fuel economy. The Picco based engines have very good power, especially on the bottom end, but their fuel economy is not as good. My personal preference and that of the team drivers tends to favor the characteristics of the Alpha line, but that's individual choice. The Picco based engine seems to have too much bottom-end power, which can make the car difficult to control when accelerating. Most of the pro drivers lean towards smoother, more linear throttle response to avoid wheel spin. Throwing a lot of dirt around looks impressive, but it tends to compromise lap times and consistency.
They're both very good, powerful engines. It's simply a matter of choice as to the type of power you prefer. The Alpha is smooth on the bottom end and strong at mid to high speed and the US Spec is really strong on the bottom and mid range and at least competitive on the top end.
Old 02-25-2009, 12:52 PM   #10
Thx for the quick reply. If I can ask, some big uses CRF clutch or which kind of clutch seems to work at best with the CRF Alphas? Thx again
Old 02-25-2009, 01:33 PM   #11
Echelon's Avatar
okay. But I heard the Alpha line is going to be a bit cheaper (than the CRF), or not? So the Alpha line is better on the top end compared to the picco based mills? The .24 looks like a good engine for my Truggy. It's a Hyper Pro, and its a bit heavier than the newer Truggies on the market, so does need a strong engine. But maybe .21 CRF will do the job, because it already has lots of power, right? But the smoother acceleration on the Alpha sounds good too... Since I used to drive fast 1/10 off-road electric.
Old 02-25-2009, 03:51 PM   #12
Super Moderator
Jason's Avatar
Send a message via MSN to Jason
Originally Posted by 1fastguy1 View Post
Hey Pitpop
thanks
MO
I ran the US spec engine with a JP-3 pipe this past weekend. Engine had tons of power with runtimes over 10 minutes.
| Team Orion | KO Propo | SPEEDLine Designs | RMS Graphix | HobbyTown USA, Rockford Il |
Jason is offline   Reply With Quote
Old 02-25-2009, 10:25 PM   #13
pitpop's Avatar
Hey Pitpop
thanks
MO
You're right, we were in a hurry to run the engines and get happy with them in a short period of time (which we did! lol). All I can say is the .24 seems real happy with the 2013 pipe. On the 3 port, we went from a 2013 to the 2050, and Cody came off the stand and said, "...so good!" so that's what we used.
Old 02-26-2009, 10:25 AM   #14
Speaking of new equipment and to keep down on starting a new thread has anyone got any experience with the Orion Vortex servos. I looked at them on orion's website a while back and now I saw them out at Stormer hobbies for a really good price for the amount of speed and torque you get with a digital servo. Are they durable and what type of warranty do they have?
RJD Hobbies, Kyosho, AKA, Byrons Fuel, Airtronics, Futuba/JR, Novarossi/Sirio, Future: Reedy/Orion
driverbob is offline   Reply With Quote
Old 02-26-2009, 11:57 PM   #15
pitpop's Avatar
I don't know anything about the servos, but there is a thread on Orion servos, you might want to check it out.
Forum Jump
MSRA Classifieds Modena AL MSRA (Memphis, TN) 1646 11-19-2009 05:30 AM
Team Orion CRF Wasp Rev X-Dyno results Nano Exclusive Nitro Engine Zone 1509 07-02-2009 08:34 AM
ORION 5300 Soldering Assistance dblhelx Electric Off-Road 6 04-26-2009 09:40 AM
Electronics, Electronics, more Electronics, & a few other items. Stratus Racer R/C Items: For Sale/Trade 46 01-22-2009 08:24 PM
Items for sale - a little of everything rctazmanmc R/C Items: For Sale/Trade 16 08-17-2008 06:07 PM
Large sale!!!! Mix of about everything rctazmanmc R/C Items: For Sale/Trade 35 06-29-2008 03:20 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
