Question bout my rush evo
can i run my rush evo with only one clutch spring without it causing damage
I'm not real familiar with the clutch on the Rush. Usually running without a spring will cause the clutch drag at low rpms. This heats up the clutch bell and bearings which is a bad thing. It also increases wear on the draging clutch shoe. The car won't tune right as it won't want to sit at idle as it drags down or stalls the engine.
