STRIPPED BOLT!
STRIPPED BOLT!
I have a couple of allen head bolts on my TMAXX that Iam trying to get out, the aleens are too small to use a dremel to make a slot and try a flat head screwdriver, and are in too deep to get a pair of vice grips on them! I have no clue how to get these things out, is there anyone who can give me some suggestions? I'd really appreciate it. Thanks in advance!:flami ng:
sounds like the point at which i would take a drill to it and drill the head of the screw off.
Ok, stupid question, i have heard to drill the head of the screw off. but what does that do? I mean, what after that? Dumb question, I know!
After removing the head of the screw hopefully you can remove the part and take the rest of the screw out with a pair of vice grips, if not just replace the part.
Me likey the grab it, you use it before?
Couple of things you can try - CA an allen wrench into the stripped socket head - sometimes will give you enough grip taht you can get it out. Just enough CA to wet surface - too much and it won't dry/cure. had mixed results trying this.
Next one - take next biggest allen wrench and file on the sides or flats of the wench a little at a time until you can drive it into the stripped head. That usually works for me, it just takes a little time.
Can minimize these kinds of probs if you use quality, hardened allen drivers and hardened alloy steel hex heads.
Go to sears they have a version of the grabit. It is the ONLY extractor I have found that works well. They are a godsend trust me. One side of the bit drills the stripped head into a cone shape and the other sider has revers threads so when you reverse it it grabs good and hard. I ALWAYS have one of these in my kit. Also they are cheap for a set at sears.
Also, most of the time when you get stripped screws you should look at your tools. The tips could be worn. Just file down the end a bit and it will grab screws like new. And make sure you pick dirt out of the screwheads before hand. This causes problems as well.
ues a left hand drill bit it will back the screw out will you are drilling
