Old 02-23-2009, 02:15 PM   #1
joeduffy987's Avatar
Default Losi xxx-nt help
Hi im new to this so sorry if its in the wrong section but here it goes
hi fellow nitro heads i was just wondering if anybody has any tips / tricks or items that can increase acceleration / top speed on my losi xxx-nt
thnks in advance
"Who are you to judge the life I live? I know I'm not perfect and I don't live to be, but before you start pointing fingers make sure your hands are clean". - Robert "Bob" Nesta Marley.
joeduffy987 is offline   Reply With Quote
Old 02-23-2009, 04:12 PM   #2
bumb
Old 02-23-2009, 04:15 PM   #3
Get a new engine/pipe and throttle servo. Will you be racing or just bashing? How much do you want to spend and how fast do you want it to go?
Losi 8ight 1.5 ~ 8T ~ XXX Buggy ~ Mini-Baja
The o''le saying goes, pay me now, or pay me later, because you gonna pay me. "Pearl_414"
Chris__RC is offline   Reply With Quote
Old 02-23-2009, 04:16 PM   #4
fast as possible racing and not sure on budget wt kind of engine / exhuast? thnks
Old 02-23-2009, 04:18 PM   #5
thnks in advance
What are you starting with for a powerplant?
John Schafer is offline   Reply With Quote
Old 02-23-2009, 04:21 PM   #6
Stock, all stock, If u cud link items be much appreciated.
Old 02-23-2009, 04:32 PM   #7
Racing a 2wd gas truck, a faster engine will ponly result in more headaches. You need to practice to get better, not a faster engine. Instead, spend that extra money on tires.
Old 02-23-2009, 04:34 PM   #8
So I'm guessing that you have the Mach .15 and RTR pipe. This set-up is already quite good for racing on the dirt. If your planning on just running in the street you have a few options.
Gearing: You can change the clutch bell gear. Stock is a 18 tooth. 19 and 20 are available. About $15 each.
Engine: You have limited gearing options. One way to get more speed is to get an engine that will turn more RPM's. Your looking at $150 plus for an engine that will turn some serious RPM's
About all you can expect is something close to 40 MPH. Stock it runs about 35 MPH.
Old 02-23-2009, 04:34 PM   #9
any u can reccomend? my irl mate said a new exhaust will work wonders but not sure
Old 02-23-2009, 04:36 PM   #10
Not with the stock engine. The stock pipe is actually quite good.....
Old 02-23-2009, 04:40 PM   #11
ok sweet wt tires you recommend on dusty track & wts the throttle servo <-- noob nitro driver
Old 02-23-2009, 04:51 PM   #12
Losi step pins in red compound work well on most surfaces. Tire selection is better answered by local racers.
Throttle servo should be fine for now. I don't remember for sure but, I think the steering servo is pretty good also.
There are a couple of upgrades that you should do. Is the reciver battery (in the car) pack rechargable or 4 AA batteries in a plastic holder? A rechargable pack is much more reliable and helps the servos work better. The stock RTR plastic rear A-arm mount is prone to breaking. An off the shelf replacement is made of much better plastic.
Old 02-23-2009, 04:59 PM   #13
The stock throttle servo is the JR z270. 50oz of torque.
Old 02-23-2009, 08:35 PM   #14
BOOST's Avatar
I had two of these which I brought from brand new and the stock engine/pipe is an excellent combo. If you wanted to change the exhaust the Team Losi tuned pipe works a treat (LOSA9332). For racing I would definately change most of the plastic to the graphite replacements...like the arms, front bulkhead/kickplate/steering brace (all 3 come together), shock towers, even the rear pivot block and the centre brace while you are at it. Make it stronger before worrying about making it faster. The RE.15 is a great motor and easy to tune. Both of my factory throttle servos stopped working and even one of the steering from memory, but there are plenty of cheap reliable servos to put in there. As for tyres see what the local guys are running.
BOOST is offline   Reply With Quote
Old 02-24-2009, 12:26 AM   #15
ok thanks guys
OCRC Raceway robertbl California Racing 13143 08-15-2017 02:58 AM
Losi XXX-S TSR6 Electric On-Road 14329 01-26-2015 07:59 PM
Losi xxx-t/mf/mf2 utracer Electric Off-Road 6 07-18-2004 07:38 PM
Losi Off-road!!! Speedo Electric Off-Road 326 11-12-2003 10:15 AM
Need Help With Losi xxx-s Kit NeO-pRo-3 Rookie Zone 10 01-01-2003 09:06 PM
Fact or Fiction: One-Ways and the year 2003 Cracker78 Electric On-Road 57 09-17-2002 08:33 AM
