Old 03-08-2009, 07:17 AM   #46
Location: 4373 Creek Road Chaffee,NY 14030 USA (716)783-5198
Trader Rating: 23 (100%+)
Default RayAracing
Originally Posted by RGraves View Post
How many times can a sleeve be pinched?
Using my method reconditioning-resizing the guys send me their P&S set once or twice. Although many of the guys sending me work regularly, requesting "Light" tightness, may possibly get a third in there. Please note, A light tightness is a resizing,is that reforming the sleeve aprox 0.0002" (2 tenths of one thousandth one inch) more or less. Comparatively, a medium tightness may be 0.0004", again more or less. To elaborate on the question I do not like resizing a sleeve to adjust "piston wear" any more than 0.0012" its life span, it then is rendered unsalvageable , in my experience. Hope this helps you guys. RayA
RayA is offline   Reply With Quote
Old 03-08-2009, 11:23 AM   #47
Default resizing ABN verses ABC
As for piston and ABN sleeve sets that with nickel plated sleeve liner, they are in a league of its own. As I stated before here, and I believe on my website you should find informative information this subject, the nickel plating on the ABN sleeve set is much thinner than chrome plating, is soft and not very resilient. Quite a few times in the season I send sets back unserviced after I inspect to find wear thru to brass base. Just to give you guys a round about summarization here, The sleeve liner wears 10:1 of piston (ABN)apposed to the other way around with ABC construction. With that said, ABN piston and sleeve sets you get one try at resizing so you want to make it right. You resize it too tight or out of round your SOL. With ABC a guy can screw it up and I can fix it 99% of the time. I love those clamp resizers and others using the inferior methods giving me extra work/job security. Anyone else have some insight on resizing? OOOr how the various methods are working for you on the track? I got another week to listen and chat online then busy as a beaver setting up new shop end this month, so I am very interested in the racers imput here . RayA
Old 03-12-2009, 05:46 PM   #48
Default shop move
Gentlemen,
Very short here to update the readers here and those planing to place order from RayAracing website order forms. There is an announcement at top of main page stating between the 17th thru 25th this month we will not be accepting new orders. Changes are as fallow: New shipping address is Orchard Park New York, New email is RayA@RayAracing.com . The winter is passed and finally will be utilizing the shop built last spring/summer.Love the way the build turned out. The move will keep busy for a few weeks starting this weekend. Enjoyed talking with you guys from this forum online and the calls received these past few weeks. Gentlemen,
Old 03-12-2009, 08:29 PM   #49
Default happy customer
ray the b3 is back to its old relieable self,thanks a ton.
smash8ight is offline   Reply With Quote
Old 03-13-2009, 07:57 AM   #50
RGraves's Avatar
Trader Rating: 37 (100%+)
Got a couple of engines back from Rex yesterday and am very pleased!
-It is more blessed to give than to receive. ~Acts 20:35
-Spec Amsoil, Jerry Welchel or Fabtech Slash
-Team Losi 8ight E- Castle Creations Mamba Monster 2650
RGraves is offline   Reply With Quote
Old 03-15-2009, 04:29 PM   #51
Default RayAracing
Steve, Your welcome. RayA
Old 03-15-2009, 05:51 PM   #52
houston's Avatar
Trader Rating: 91 (100%+)
ray and his equ. is the only resizing equ. i would ever use period
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 03-15-2009, 07:13 PM   #53
yeaklet4's Avatar
Trader Rating: 34 (97%+)
Originally Posted by yeaklet4 View Post
i just gotone done from os rocket and i cant even turn it over with no glowplug in it. i have not ran it yet so we will see then.
he is my update 4 hours on a drill full speed and 3/4 gallon of fuel and it still gets stuck at tdc by hand with no plug u cant turn it over by hand still. but im changing the rod now cause its sloppy already
yeaklet4 is offline   Reply With Quote
Old 03-17-2009, 08:05 AM   #54
Default RayAracing
Houston, Glad you see resizing tooling+service quality.
Yeaklet4, you should have not attempted rebrekin the resizing results discribed. If your lean on the funds pay the return shipping and I will loosen the tight fit Free. My emil address is RayA@RayAracing.com
Old 08-16-2009, 06:53 PM   #55
Adro's Avatar
Hi,
i got my speed sleeve pinched (not by Ray)and its come back and seems to be to tight (it stalls my starter box with no glowplug in it) is there a way to loosen it alittle or is it time for a new piston and sleeve?
Adro
Adro is offline   Reply With Quote
Old 08-16-2009, 08:51 PM   #56
22Racer's Avatar
Trader Rating: 67 (100%+)
Originally Posted by Adro View Post
Hi,
Adro
I have heard some get them too tight. I do have a method to loosen it up but you would have to send it to me. Even though it is more work than a standard pinch I will still just charge the $15.00 I normally charge. And maybe ask for a refund from the place you sent it?
Rex
Rw modding and engine repair http://www.rw-mods.com
Sleeve resizing $15.00/ motor rebuild $30.00
Argus engine distributor/Avid bearings/ Alpha engines/
Fx Royal engines/ Maxy Engines
e-mail rwmods@yahoo.com Rex Welch
22Racer is offline   Reply With Quote
Old 08-17-2009, 01:15 AM   #57
Adro's Avatar
i live in australia so it would probably cost me more in freight than it would to get you to fix it, If i heat it up real hot then force and old piston in there and let it cool would that help??
Old 08-17-2009, 07:19 AM   #58
marshon50's Avatar
Default +1 for RayA
Just got my Vspec back, broke it in on the track heat cycling during practice and qualifiers. Finished 2nd in the Amain truggy w/ an engine running so fat I'm barely getting 6 minutes run time. Can't wait til I can get her leaned in and get my 9 minutes back. Would've run the race w/ a normal tune. THanks to RayARacing, for the medium pinch!!!!
marshon50 is offline   Reply With Quote
sleeve pinching? scurran Onroad Nitro Engine Zone 43 08-30-2010 05:00 AM
Resizing your used piston & liner sham@SINGAPORE Malaysian R/C Racers 18 09-20-2009 07:42 PM
Motor Mods.....sleeve's pinched racer_RR R/C Items: For Sale/Trade 178 07-21-2009 10:58 PM
