Old 02-21-2009, 06:36 PM   #1
Trader Rating: 27 (100%+)
Default Clutch assembly problem
Hey guys, probably a stupid newbie question...
I'm tryin to assemble an Ofna buggy clutch, 3 shoe, shoes seem to go on ok, but I'm having a problem with the spring - if I push the shoe/pring down onto the stud too much, I can't pull the spring back because it hits the nut, but if I try to pull the spring back before its on the stud, it just comes off and doesn't sit over the stud anymore
I'm using a regular clutch tool..
I watched videos on youtube, it seems pretty straight forward but I can't see up close enough what is happening with the spring
Is it the way the spring is wound? The part that goes to the nut is lower than the part that goes on the shoe, I guess if it were the other way it would work. The shoes/springs are from XTM, but look like they should work.. they are plastic
Anyone got a clue? Really want to assemble my big block already
Thanks!
spawn_x is offline   Reply With Quote
Old 02-21-2009, 09:41 PM   #2
that's how they normally look, however mine are flipped around - the part the grabs onto the nut is on the bottom, making it like impossible to slip on..
do XTM engines spin backwards or something?
Old 02-21-2009, 09:58 PM   #3
BIG RE's Avatar
Trader Rating: 32 (100%+)
on the xtm cars I have worked on, I know that the x-terminator has the shoes on backwards form the factory, I tried to put them on the normal way, and the way that they are molded would not allow it. Just get the ofna(ho bao) plastic shoes, they last a long ass time and are pretty inexpensive
BIG RE is offline   Reply With Quote
Old 02-21-2009, 10:01 PM   #4
that makes perfect sense, damn it.
back to hobby people
Thanks dude.
Old 02-22-2009, 12:04 PM   #5
BIG RE's Avatar
you're welcome
Old 02-22-2009, 06:24 PM   #6
Yep, picked up some associated clutch springs from another shop, and put the clutch together with no problem
go figure, stupid XTM
Serpent 705 J_Longbrake Nitro On-Road 4252 02-22-2015 11:34 PM
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 01:47 PM
8ight clutch??? 1cougar1 Nitro Off-Road 28 01-21-2009 08:34 PM
Please Help Muah! Speedjunkyz Nitro On-Road 36 09-05-2008 07:13 AM
