Old 02-20-2009, 03:26 PM   #1
Rip It Racing's Avatar
Default Is my 4wd bad?
Im having a problem with my center diffs. This problem is on my Ofna MBX. I know when you turn 1 wheel, all wheels should turn, right? well this buggy doesnt. the front spin together and the rear spin together, but not all 4 at the same time. now, when I turn the spur gear, all the tires spin together and when i roll it on the ground. can someone direct me to a cure? thanks, id appreciate it!
Rip It Racing is offline   Reply With Quote
Old 02-20-2009, 03:40 PM   #2
vladconnery's Avatar
Trader Rating: 35 (100%+)
Start with your diffs check the fluid if its pearl in color. then your diffs gears are stripped this occurs if your on throttle when coming back in contact with the ground after a jump.
KO PROPO EURUS
Kyosho: TKI3, TKIe Tekin RX8 Gen2
vladconnery is offline   Reply With Quote
Old 02-20-2009, 03:58 PM   #3
Actually it sounds as if it is working properly............. Do you understand what the center diff does? It does not act as a solid shaft.
If you set 3 wheels on the ground and then turn the fourth, the center diff only should spin (if the brakes are released).
John Schafer is offline   Reply With Quote
Old 02-20-2009, 08:23 PM   #4
rced1's Avatar
Trader Rating: 17 (100%+)
If you turn both front wheels then both back wheels should turn the same direction. If the back wheels do not turn it is time to tear apart the center diff. You should re[lace the diff oil regularly and inspect the gears.
Slow is fast.
rced1 is offline   Reply With Quote
Trackside Matt M. Wisconsin & Illinois Racing 17044 01-20-2017 09:34 AM
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 05:09 AM
SS Raceway in Tampa Rojna Florida Racing 5042 07-15-2014 12:03 AM
Somebody Make This into a 1/10 Scale Body Hawk6 Electric On-Road 70 09-27-2011 09:38 PM
SC10?!? trdsupra88 Electric Off-Road 926 07-20-2009 12:29 PM
BIG BAD REVO 3.3 - LAST CHANCE SALE - THIS IS THE ONE R/C NYC R/C Items: For Sale/Trade 9 02-04-2009 04:20 AM
Driving - Practice Theory syndr0me Electric On-Road 105 03-06-2007 07:36 AM
